Useful Battery Tips
hmp10
Founding Member
Naples, FL
Model S Plaid, Odyssey
DE Number
154
033M4EXG
"Engineering Explained" recently posted a very good overview of how to increase the service life of your EV battery pack:
Good video but meant for techies. My wife who is a non-techie, figured out something simple. She drives typically 20 miles a day. Her car Ioniq 5 averages 4 miles per kWh given her driving monthly is about 70% surface streets and 30% highway and she drives at speed limit. She needs about 140miles a week. That is 35kWh or 45% battery in her car. So she can charge to 80% and then again charge when it dips to 35% knowing that the lower limit to prevent the 12V battery from not charging is 20%. 15% is 45 miles of range which is 2 days for her. She then noticed that charging from 35% to 80% on a typical EA charger was taking about 25min in her case. Then she looked at EA chargers close to her daily routine and decided that she can charge 2 times a week just 55 to 80 in less than 20 min of shopping. Her thinking was simple. She rarely needs more than 35% of battery for her longest drive. 55% to 20% is that. She has no more range anxiety and interesting that the video basically says that she is doing the right thing!
Yes, it does give the technical reasons for how batteries are best treated a certain way. But each segment ends with a straightforward "do" and "don't" to minimize the type of damage covered in that segment.
And the final wrap-up was simplicity itself: on a daily basis, set your charge limit around 75%; if you have home charging, keep the car plugged in at all times; and if you need to charge the battery fully to prepare for a trip or while on a trip, don't worry about it . . . as long as you don't let it sit at full charge for a prolonged period.
About the worst thing you can do, as least regarding the factors that are in your control, is to charge the car fully at a Level 3 charger, then park it at home, driving it for daily use until you run the battery down low, and then return to the Level 3 charger to do the same thing all over again.
