Turn signal lever
Chandi23
Touring
Does the turn signal lever return to the original position after a lane change ? In my situation, it does not. I have to manually bring it back up. Thanks.
Yes it does. It is a two position lever. The first position is a lane change indicator where you just lightly depress it and it times out in a matter of seconds. The other is a turn signal indicator where you push past the detent and it goes off after a turn. Regardless, the turn signal lever returns to a neutral position.
This is pretty much industry standard. If the OP's car does not, he needs to call customer care.
