The Got Boost wheel setup - Maximum everything
037
Gravity GT custom wheels
22x10.5” front
22x11” rear
295 tire front, 315 rear.
Detailed photos after install. This will be my winter clear road setup with some snow and ice capability, but mostly clear road.
Tire: Continental 860 S
Custom spec, forged, 32lb per wheel.
Capacity: 1300KG
22x10.5” front
22x11” rear
Capacity: 1300KG
Great setup.
Do you need any modifications/ addition such as spacers, etc?
Where did you get the wheels from?
And showing my ignorance here, can't you use the Lucid 22 wheels all around?
Great setup.
These are custom made to my spec, if they fit the way I mathed it, no modifications, direct fit.
As far as Lucid 22”…they aren’t made for a square setup, front and back are different and not interchangeable due to offset. Front will only fit rear if 22” and none of the rear will clear the front comfortably. So…don’t mix and match Lucid wheels and tires out of factory spec.
22x10.5” front
22x11” rear
Capacity: 1300KG
Curious with your compromise nothing on wheels and tires you haven't spec'ed magnesium wheels. I still remember the first time I changed a flat on my Porsche 944 I nearly through the tire/wheel the first time I lifted it. It was soo much lighter than I was used to.
