[Suggestions] Software features from other brands that make sense
Your first request is already there (and I think has been for awhile, Lucid just added the rear seats). If you have the ac/heat on and shutdown the car the same settings will be on when you next get into the car.
can't comment on music apps as I only use Sirius XM
This is what HUD is isn't it? You have to purchase the Tech package to get this feature
The parking cameras already can come on. I know they come on when you put the car into reverse and you can also hit the "P" in the lower left of the main panel
For Dream Drive 2 Premium just enabling adaptive Cruise Control gets this for you. I do not have Dream Drive 2 Pro so can comment on ADAS
Let me check again, I don't think the AC started when I got in the car, only once when I pressed the brake pedal. I would like AC to run when I unlock the car though from the key (I use that as remote climate essentially).
I have the hud, it doesn't display a mini map either. Both screen does show the turns but not overlaid on a mini map showing other streets. My EQS used to that which was handy in downtown settings.
With DD2 Pro, you can either choose to activate ADAS directly but then it only activates once it detects lanes or activate ACC first and then ADAS with another press. Not a big issue obviously but would nice to be able to just activate whatever is best available option with a single press.
