I am planning on adding a dedicated solar PV charging station for my 2023 Lucid Air Pure. My old house electrical infrastructure would require much upgrade to get a house charging station. The solar would be on my shed, wired to a battery bank and then directly to the Lucid. The battery is a EcoFlow Delta Pro X and is a packaged kit with the batteries and inverter all good to go. It would not be connected to the house system nor the grid- totally stand alone. I can use the 240 volt plug from the Lucid direct into the inverter or use a Lucid wall mounted charger in between. I am worried about the "handshake" between the car and the inverter. Some sort of software gremlin that will cause error codes. Perhaps the Lucid wall charger would help smooth out any issues?
I think it should work. Any advice or concerns from the smart people? (not an electrician . . .)
