niejelow
- Nov 18, 2021
- Connecticut, Keywest, Lugano
- Lucid Air Dream P
- DE Number
- 45
It’s really a shame that they don’t have SiriusXM in the audio selection.
It definitely is, I wonder if you can get an online app only account?It’s really a shame that they don’t have SiriusXM in the audio selection.
I use the app on my phone and connect to truck using Bluetooth. Cinemagic is only on the app.The question is can you even load the XM app into the Lucid UI.
Sure, that’s always an option, but very inelegant. I get into my cars and my phone stays in my pocket. I’d find it a real pain to have to take it out of my pocket, find the app and then tune to the channel I want. Then if I want to change the channel, it becomes a safety issue while driving.I use the app on my phone and connect to truck using Bluetooth. Cinemagic is only on the app.
Lucid is suppose to have Apple Wireless Car Play but I have not heard if it is working yet. In any case, I agree that Lucid should have XM native on the UI.I’d consider using a wireless CarPlay dongle
Frequencies | 2332.5 MHz,2345 MHz |
Frequency Range | 2332.5 MHz - 2345 MHz |
Mode | RAW |
Modulation | OFDM,PSK |
ACF | — |
Emission Designator | — |
Bandwidth | 12.5 MHz |
Huge real timeIs there any benefit to sirius over Spotify though?
Yes 2.3 GHz is not attenuated by glass so it can be placed anywhere that has a view through the glass roof.The antenna can be mounted out of sight.
I have added satellite XM to my Tesla Model 3 an Y and in both cases I was able to hide the XM antenna out of site. Actually on the Model 3, it's placed on the rear deck lid as far back as possible. Luckily, the rear deck lid is mesh metal and the XM antenna sticks on it very nicely.Yes 2.3 GHz is not attenuated by glass so it can be placed anywhere that has a view through the glass roof.
The history of the shark fin antenna can be traced back to AM/FM radio. Many cars had an antenna in the rear center roof sticking up. Replacing it with a shark fin streamlined the appearance. Inside the body of the shark fin, one finds metal foil stuck around it - basically a long antenna wrapped inside. I've converted many cars from regular antennas to shark fin. On an older Prius, Toyota sold an GPS kit that had you mount the satellite antenna on a piece of metal under the front dash. This was probably easier than routing the antenna elsewhere. I guess the shark fin is a convenient place now for XM and GPS antennas. The original Nissan Leaf had an antenna sticking up at the rear, but the GPS antenna was elsewhere - one would think they would want to combine them in one place.But there must be.a reason why almost all manufacturers use the shark fin antenna on the roof. I can only assume it gives better reception with fewer dropouts than if it's mounted elsewhere.
My Tundra has both, terrestrial was replaced with a stubby. There's a low profile antenna for satellite on roof of cab.The history of the shark fin antenna can be traced back to AM/FM radio. Many cars had an antenna in the rear center roof sticking up. Replacing it with a shark fin streamlined the appearance. Inside the body of the shark fin, one finds metal foil stuck around it - basically a long antenna wrapped inside. I've converted many cars from regular antennas to shark fin. On an older Prius, Toyota sold an GPS kit that had you mount the satellite antenna on a piece of metal under the front dash. This was probably easier than routing the antenna elsewhere. I guess the shark fin is a convenient place now for XM and GPS antennas. The original Nissan Leaf had an antenna sticking up at the rear, but the GPS antenna was elsewhere - one would think they would want to combine them in one place.
