herodotus480
- Aug 2, 2024
- Tesla Model S
I just placed an order of a Lucid Air Pure. I'm in need of a fresh referral code. I was told a referral code would be rejected if it has been used too many times.
Picked my Air up a couple of days ago so this guaranteed to workFeel free to use mine - it’s unused so far 3ISO9061
Design Your Lucid Air | Lucid Motors
Design your award-winning Lucid Air electric car. Build and price a Lucid Air Grand Touring, Touring, or Pure.www.lucidmotors.com
Thank you. I used your code and it was accepted!You can use mine, its not maxed out and will work
referralCode=DGXRGF4V
Design your award-winning Lucid Air electric car. Build and price a Lucid Air Grand Touring, Touring, or Pure.lucidmotors.com
Hi! When did you purchase your Lucid Air? How does one know if a code is maxed out or not? As I’ll only get one try to use a code, I want to make sure I’m using a code that will definitely work. Thank you!Feel free to use mine - it’s unused so far 3ISO9061
You can use mine. 1LXEQUIII just placed an order of a Lucid Air Pure. I'm in need of a fresh referral code. I was told a referral code would be rejected if it has been used too many times.
Hi Rahul,Hi! When did you purchase your Lucid Air? How does one know if a code is maxed out or not? As I’ll only get one try to use a code, I want to make sure I’m using a code that will definitely work. Thank you!
We can track our number of uses - mine currently sits at 0 so you're good to goHi! When did you purchase your Lucid Air? How does one know if a code is maxed out or not? As I’ll only get one try to use a code, I want to make sure I’m using a code that will definitely work. Thank you!
