- Sep 10, 2021
- California Central Coast
- White Gravity GT
- I79OY1W7
Guessing forward and reverse were mixed up? Hard to say too, as new member with 1st post.
I thought that too, but my post was deleted (mods, could you DM me a reason? just want to understand the rules, thanks!).Guessing forward and reverse were mixed up? Hard to say too, as new member with 1st post.
but I will not drive with the extreme backward when my intention was to go back I will look at the screen to watch for incoming cars and push the pedal very slowlyGuessing forward and reverse were mixed up? Hard to say too, as new member with 1st post.
I called the Lucid and they are investigatingDon’t let anybody do a hard reset on the car! Have Lucid pull the logs first. They will be able to tell whether it was a mechanical error or some other cause.
Fob has nothing to do with resets. I'm not sure what you mean about "hard reset" but I do know that if you do it it can delete the logs at Lucid might need to identify a problem.The service department responded and mentioned that there are known software issue when user steps on brake while tapping on acceleration pedal. I don't think I did that and I was using the hold mode. I check all profiles on the car. I did find one of the user profiles was set to Roll mode which I am not sure why. Anyway, I switch all profiles to Hold mode and disable the creep mode. Also, I bring the key fob with me. In case when something weird happens, I can hard reset the car.
That's a scary and bad accident. I think asking Lucid to investigate is the right thing. Hope you'll get the right answers.Hello Everyone,
I just got a Lucid Air Touring about 3 weeks ago and I’ve driven about 1500 miles. I loved it. However, last Friday, May 17, 2024, I was driving from LA to SF with my daughter. I had to recharge at Patterson, but when I got to the shopping center, all the chargers were occupied.
I decided to drop my daughter off at a fast-food restaurant nearby. After she got out of the car, I put it in reverse to back up and get in line for a charger. However, the car suddenly accelerated forward at high speed, and I hit a dental office in the shopping center, breaking the glass windows. The front end of the car was damaged, and I had to get out from the back door. No airbag was deployed.
The car was towed to a garage, and we rented a car to continue our journey. It was extremely scary. I’m planning to call Lucid this morning to ask for an investigation.
