- Mar 7, 2024
- Bedford, NH
- 2023 AT
- 9A7U8E5H
Hi all,
My 2023 AT has around 7000 miles on it and I recently noticed that the range drop from 336 to 334 when charged to 20%. not a huge drop but a dip nonetheless. After a bit of searching I landed on http://testmycode.cc, which showed me the following:
"batteryState": {
"range": 539,
"chargePercent": 79.90000119060278,
"kwHr": 67.69999848678708,
"capacityKwHr": 84.71999810636044,
"batteryHealth": "WARNING_OFF",
"lowChargeLevel": "WARNING_OFF",
"criticalChargeLevel": "WARNING_OFF",
"unavailableChargePercent": 0,
"batteryPreconStatus": "BATTERY_PRECON_UNAVAILABLE",
"batteryPreconTimeRemaining": 255,
"batteryHealthLevel": 95.5000014230609,
"evsePowerLimited": 0,
"bmuSoftwareVersionMajor": 4,
"bmuSoftwareVersionMinor": 12,
"bmuSoftwareVersionMicro": 22,
"batteryCellType": "BATTERY_CELL_TYPE_LG_M48",
"batteryPackType": "BATTERY_PACK_TYPE_AIR_18",
"maxCellTemp": 28.80000191926956,
"minCellTemp": 26.700001887977123
So here are my questions
1) I thought I had a 92kwh capacity, and charging to 80% should show my current capacity at 73.6 but it shows 84.7 in capacityKwHr
2) If capacityKwHr is meant to be max capacity and not current charge levels, then my battery degradation would be just short of 9% (84/92) )in 7k miles. that seems excessive or just wrong.
3) if batteryHealthLevel is to be factored in at 95%, then 95% of 92 and a SoC of 80% should yield current change level of 70kwHr
I'm clearly not understanding what I see. Can anyone help me understand this data? also range says 539, but my EPA range is supposed to 420? (based on 336 / 0.8)
I tried searching and I apologies if this has been discussed to death. I couldn't find it quickly
Thank you.
"batteryState": {
"range": 539,
Thank you.
