- May 7, 2025
- GDE#257, MachE-GTP, MX
- Gravity DE Number
- 257
My wife and I watched them all. Thank you @outofspeckyle, @Cyp , and everyone else involved! I specifically stopped reading this thread as each episode was posted so as not to be spoiled.
*** SPOILERS BELOW ***
We were wondering why @outofspeckyle didn't try rebooting the Gravity earlier in the race to clear the stuck cameras? Also, did you find out more info from Lucid about the charge port errors?
Congratulations to both Gravity crews for winning the race. The result reinforced our decision to replace 2018 Model X 100D with the GDE. I've done many coast-to-coast (Seattle to Maryland) and Seattle to Phoenix trips in the X. I did not optimize for max charging curve like the X team did, choosing to drive from 80% to the mid-teens, except for the stretches that needed maximum range between chargers. But also, my charging curve is much lower than the current models. 120kw peak was normal in 2018 and although Tesla increased the charging rate over time, 150-170kw is typically the maximum I ever get.
With a couple of long trips in the Gravity, we have been very pleased by the increase in range between charges and the decrease in time needed. Again, we tend to charge to higher percentages and the car is typically ready to go before we are, and her range is greater than our bodies have.
Also, since we don't drive cannonball style, the BMS has time to get resting pack measurements, so BMS Sway probably won't impact us much.
Again, thank you for the long form content OOSpec posts. Your early reviews of the Gravity helped us learn about this wonderful car.
