New Tech Talk - Inverter
joec
Referral Code - MX1KDTYY
Moderator
Supporting Member
San Francisco, CA
Air Touring
MX1KDTYY
Posted to YouTube today. Enjoy!
He mentions that the GT front inverter has 3 silicon carbide modules while the GTP has 6. Is that for increased efficiency? Fewer chips, less energy passing through?
The first 3 minutes and the last 3 minutes is all that is needed to understand how it works and how it is put together.
As I understood it the extra modules are to accommodate the need for less error in communication, because as horsepower increases the fluctuations in HP are more noticeable if you don’t have more processing precision. This whole video is awesome, he explains wave mechanics very well. I liked that he pointed out the same principles are used in digital audio, where you’re putting multiple rapid digital samples in sequence to replicate an analog sine wave (aka sampling rate in digital audio). The challenge to overcome here is the Nyquist limit, as you will get an alias frequency of whatever half the sampling rate is. This is not a problem in digital audio above 44.1khz as your ear can’t perceive 22khz which would be the alias frequency. However, in the extremely high frequencies of the triphasic sine wave he mentions needed to turn the permanent magnet motors, if you had an alias frequency at half of whatever the desired frequency was, you’d have some serious fluctuations in power output. I’m not a mechanical engineer so I have no idea how Lucid would compensate for this, or if it’s even necessary to, but I’d assume they’d put some sort of filter in to block anything at or below the Nyquist frequency.
He tells us that the stator inductance is used as a filter since inductors are very good at smoothing current. A very nice design by Lucid to tune the inverter and motor together.
Ah I didn’t get that part, make sense.
Since the GT's front motor has lower power output than the GTP's, current levels are correspondingly lower. One set of SiC switches can handle the GT motor's maximum current without overheating. Two sets of switches are needed to handle the GTP's higher motor current without overheating.
If you use two switches in parallel to handle a specific current, the two switches together (!) produce only half as much heat as a single switch would dissipate carrying the same current. That means that each of the two switches produces a quarter of the heat that a single switch would generate, increasing overall efficiency over most operating ranges and reducing the load on the cooling system.
