Multi-minute delay on live display and complete interface freeze
djeuch
Southeastern Pennsylvania, USA
2025 Lucid Air GT
Had an odd situation two days ago on my 2025 AGT. Video is attached but what happened is that the entire top and pilot panels got frozen in parking mode and none of the buttons/displays would change no matter what I did. I pulled over, and then noticed the display was basically replaying my entire drive through the neighborhood! You can see that I'm completely stopped but it's actually playing back my drive from 1-2 minutes prior. The video isn't the entire loop, but it covered from my driveway all the way to the place I stopped.
Turned around, went back home, and it continued to play back with about a 2-minute delay. Parked the car, plugged in, and walked away but apparently not long enough the first time because when I returned a minute later, still frozen. Left and stayed out of range for 5 minutes, came back, and the Infotainment system appeared to be booting up from a complete restart.
I did use the HomeLink immediately prior, so I think something about HomeLink froze the interface. I'm afraid to try and reproduce it!
Edit: I can't seem to attach a video so here's a link:
2025 Lucid Air GT Interface Freeze
Was it terribly hot when you started driving? Almost seems like the CCV was overheating since it was still kind of working, but on a significant delay. I don't know what protections Lucid has in for that hardware, but a lot of computers would throttle the main processor in an effort to reduce the temps down a safe operating temp.
You may want to reproduce to see if it is truly a homelink problem, and then maybe do a hard reset to see if that'll help it recover quickly. if you're able to reliably reproduce, I'd send what happens to the software feedback email. If you start seeing the slowdowns more frequently without engaging homelink, I'd try to get with your local service center to see if there was something wrong with the CCV.
Not hot, in fact, it's pretty cold the last couple of days. It's been okay since then, but I do think it was something where in the code, the HomeLink piece is blocking multi-tasking with the rest of the system.
When I know I won't need the car for a while, I will try and reproduce. I'm pretty sure the system self hard-reset. (I did my own reset 2 weeks ago).
