Lucid map in pilot panel
NLH
Lucid Air Touring 2025
If I’m using the cars navigation system, and I’m going to a destination, the map shows in the screen up top, the copilot panel. If my pilot panel is not showing the map, but is showing the climate control screen, for example, how do I access the map on the pilot panel?? There doesn’t appear to be a swipe down capability from the navigation map in the Copilot panel
Do you not see a little window that looks like it connects to the upper screen at the top of the pilot panel?
You don't swipe the map itself, per se, but rather the navigation box on the left side of that display. Also, you can do as the previous reply mentions and drag the partially-visible window that's at the top of the Pilot Panel. It can be difficult to see, depending on your seat position and lighting, etc. While the Nav or Audio screens are up top, just place your finger against the top edge of the Pilot Panel (your finger may even hit the dashboard trim) and drag downwards.
