Lucid Gravity 3.4.0 software update
Looks like I’ll have to reconnect the WiFi in my Gravity 🤣
Nick said rollout starts tomorrow.
Improved Blind Spot, Rear View and Surround View Display image quality
As much as I love all the bug fixes, I'm actually most interested in this - hopefully Blind Spot cameras can graduate from 480P quality to at least 1080P quality.
The camera feeds are low quality, but coming from Tesla I’m happy Lucid has actual blind spot monitor warnings in the side mirrors. I don’t have time to take my eyes off the road long enough to look at the camera view to see if there’s a car there. I check over my shoulder, then look at the side mirror.
That's true. The HUD shows the yellow triangle too
After being on a loaner Air, I lost hope the Gravity's cameras can be improved much
I'm finding walkup/walkaway more reliable and quicker with the new fob software (02.35.08), but that's just my subjective perception. Will see whether combined with 3.4.0 it's even more noticeable.
It's not subjective, I've measured it. However, see #7. The battery drain is lower while sleeping or awakened from fob movement. The fob will still sleep with no fob movement after ~53 seconds like it used to if out of range. However, since the fob stays awake within range of the car and the range is longer, you may have to keep the fob farther from the car or shielded.
Unfortunately, without some impractical instrumentation, there is no way to know if the fob is awake. This is on the 3.2.20, presumably 3.4 will correct this.
Lucky you had higher end loaner Air, mine didn't even have blind spot cameras
Yes agreed, both the mirror lights and hud triangle's are usually all I use too and then I check over my shoulder. But I'm a video codecs engineer at heart and just want my high quality video everywhere
It may also be that both the car and fob need to be running updated software for the “fix” to work
This is the most likely scenario. When you have 2 independent components (e.g., keyfob and car) each with their own software versions, each side has to be compatible and know how to work with a wide range of versions on the other side. The keyfob probably runs a slightly diff. set of code when it knows there's 3.3.20 (or even earlier versions of the car's firmware) than when it sees a 3.4.0 car, and needs to behave reasonably well in both cases, but the bulk of the fix would be in 3.4.0.
where are you guys following Nick for those updates?
Was hoping for the big three-
Carplay
Phone as key
Hands free DD
But I do acknowledge cleaning up most of the bugs is priority
Hopefully this one addresses a majority of the remaining quirks and the upcoming releases can start to take a pivot and deliver features. Between Decembers update and this one, they've certainly tackled a lot of the issues that had been plaguing owners since deliveries started.
onwards and upwards!
