Lucid Bear Front Plate
martinjlm
Detroit, Michigan
2023 Air GT (White)
In a few days I will (finally) have my '23 AGT delivered. It is coming from a state that requires a front plate, so it has the front plate bracket installed. I live in a rear plate only state. I'm pretty sure that removing the bracket will result in unsightly holes on my front bumper.
I've seen YT videos of people visiting Lucid parlors where the display vehicles have a Lucid Bear on the front plate holder. Any thoughts on where / how to get ahold of one of these?
Might just be tape that’s the way Teslas are
If you want the particular plate, honestly I’d just call Lucid service department and ask em they’re usually pretty chill. Very busy right now but.
You can sign a waiver to not install the front bracket. They’ll just leave it in your trunk.
i think because it is a 23 agt, the car is likely used and already has the front bracket installed. op is asking to have a placeholder bear plate instead of a regular license plate because removing the bracket will have holes. nothing they can do for a bracket that is already drilled and installed.
@funnynardo "nailed" it. Bad pun intended.
I'll check in with Lucid Service and see if they have any ideas.
Thanks all.
I initially had the front license plate installed by lucid when I got my car, then i regretted it lol
After about a year later, I ditched the front plate for an adhesive license "sticker plate", and it looks so much better!
The adhesive plate covered the holes well. This is doable
I like that idea, but I'm pretty sure it's not available in Michigan. There is no front plate required, so there is not a need to accommodate a sticker.
I think this jacked up California bear license plate is fun.
