LIDAR - Safest car on the road potential?
It's remarkable the way some Tesla enthusiasts (maybe I should restate that as FSD enthusiasts) seem to struggle so mightily against the cognitive dissonance of Waymo successfully deploying autonomous vehicles much more broadly than Tesla while simultaneously believing that Tesla is fundamentally the leader in autonomous driving. Admitting that Waymo has delivered a very competent autonomous driving solution into the market while still believing that FSD has a lot of promise would seem to be a much more realistic place to be, without requiring strange mental gymnastics to reconcile the difference between what you want to be true and what the facts on the ground show. Why have a cult-like devotion to a corporation?
What you're not getting is waymo uses server grade hardware. Terabytes of memory. Terabytes/s of memory bandwidth. Tens of thousands of tops. They use 360 spinning lidar, HD maps, etc.
These HD maps on their own are quite large so it is impossible to store an HD map of the U.S. on a consumer car.
This technology consumes 4000+ watts so unless you like having a car with 100 miles of range, no road tripping ability, and a battery that dies after only 6 hrs of continuous use, good luck.
The long standing argument by waymo and their engineers across reddit and other platforms is that the type of self-driving tesla and other consumer cars are pursuing is not possible. Camera only is a scapegoat for the fact that the type of driving tesla is pursuing is not possible for reasons other than being camera only.
If you remember from the early days of FSD you could cover up half of the cameras and the car would not throw any errors or drive any differently. What this seems to suggest is that there is a memory bandwidth limitation or some kind of compute limitation with processing a lot of sensors, and at any time you want to drive with the least amount of sensors possible. If you look at chinese cars with much better camera placement to see cross traffic, radar, lidar, etc. it seems to not provide any safety increase, which suggests they either are not able to effectively use them, or they lack compute to use them.
The only place they seem to have any benefit is in low speed parking where latency is not an issue due to speed.
Every time one set of claims gets taken apart you don't respond to it, you just post a fresh set. The fatality claims from yesterday are gone, no acknowledgement, and now it's hardware. So let's do this one too, because almost nothing in it is right.
"HD maps are quite large so it is impossible to store an HD map of the U.S. on a consumer car."
You're posting this in a Lucid forum. Lucid's own Highway Assist has used high definition maps since the UX 2.4 update in 2024, and the hands-free driving that just rolled out to Gravity on DreamDrive 2 Pro only works on pre-mapped divided highways. GM's Super Cruise runs on lidar-scanned HD maps covering about 750,000 miles of North American roads, pushed to cars over the air. Mercedes Drive Pilot, the only certified Level 3 system you can buy in the US, uses lidar plus an HD map stored in backend data centres and updated constantly. Nobody stores a map of the entire country on the car. Maps are tiled and streamed for the roads you're on, which is how every one of these systems has worked for years. That's not an obscure fact. It's how the car in the OP's garage works.
"Waymo uses server grade hardware. Terabytes of memory. 4000+ watts. 100 miles of range, battery dies after 6 hours."
Waymo has never published memory, bandwidth, or wattage figures for its compute, so those numbers came from nowhere. What Waymo has published is that its 6th generation Driver cut sensor count by 42%, is expected to cost under $20,000 per unit, and is now running driverless across multiple cities. The 5th gen Jaguars have been in paid service for years running most of the day. If the compute drained the pack in six hours, the business would not exist.
"You could cover up half the cameras and the car would not throw any errors or drive any differently. What this suggests is a compute limitation."
What it actually suggests is the thing NHTSA is investigating. The open Engineering Analysis into FSD, covering 3.2 million vehicles, is specifically about the degradation detection system failing to notice when cameras are impaired by glare or fog and failing to warn the driver until right before the crash. You just described a known safety defect and presented it as evidence of clever engineering.
"The only place lidar seems to have any benefit is in low speed parking where latency is not an issue."
Backwards. Lidar is valued for long range detection at speed. Waymo's 6th gen suite sees out to 500 metres. Mercedes puts its lidar in the grille for highway Level 3, not parking lots. GM's entire hands-free domain is lidar-mapped highway. Low speed parking is where ultrasonics and cameras do fine. You've got the one use case exactly inverted.
"The long standing argument by waymo and their engineers across reddit is that consumer self-driving is not possible."
No source, again. Same as the Rivian cover-up, the Bilibili video, and "effectively zero at-fault fatalities."
You've been here 17 days, 43 posts, almost all of them about Tesla, and people in this thread are now hitting the ignore button. That's not because they can't handle a different opinion. It's because you keep stating things with total confidence that are checkable and wrong, and when they're checked you move on to the next batch.
Sources:
I posted the fatality claims and I believe it was removed for personal attacks by a moderator. I'm not going to explain again.
Lucid is not using HD maps at the same definition that are being used in a self driving car.
hd maps in self driving cars contain a lot more than just lane info. These would contain high density point clouds and they contain identifying information about every object that is being scanned, like whether it is a pothole, speed bump, etc. There is a lot more detail about how to drive on the roads vs. just a simple accurate lane map. There is definitely stuff I am forgetting.
Every object waymo scans with the point cloud has a "damage score" which is why waymo accidentally ran into that telephone pole in arizona. This would provide a level of safety as in a human could avoid a deadly accident (hitting a pedestrian) by crashing their car into something soft. Whereas maybe a tesla thinks every object is hard and this accident is unavoidable. This would also be an issue if you say swerve for a balloon when it is totally safe to hit.
There was an engineer on reddit who worked at cruise and he personally stated that the maps were very large and it's not possible to store an entire map of the U.S. on a car.
The way these maps are used is you scan the road with your 360 lidar and sync the output to the HD map. This gives you centimeter accurate position of where in a scene. Consumer GPS can be 20m or more off from the map which can cause you to miss a turn, think you are in a different intersection than you really are, think you are on the wrong road, etc.
The idea is at scale if you have a safety issue like the car can't identify a pothole or a speed bump, the HD map can take care of any scaling issues. The argument is this level of prior knowledge is required for safe, unsupervised driving. This has nothing to do with AI, E2E neural networks, etc. because those can still be used in a solution like this.
There was a video from a girl named Sophia Tung. She rode in a waymo for 6 hrs and had a full charged one (she lives near the depot) and the car started at 80% (79% since it lost 1% since she got in) and the car gave up after 6 hrs to return to the depot and recharge. It cuts off around 10%. She tried riding all day. There are also videos where the energy consumption screen is visible and it shows hilariously low ranges (like 30 miles remianing) with quite a large percentage of battery left. In the sophia tung test she went only 83 miles before the car gave up.
This no longer the case. FSD requires all the cameras to be visible. This literally hasn't been the case for at least 3 years. One of the limitations of FSD is that when the pillar camera on the sides see nothing (i.e. you're driving down a dark rural road at night and nothing is lit up), it thinks the camera is blinded and FSD gives an error. They have since solved this problem it seems.
I'm talking about chinese vehicles where lidar seems to do nothing for accident avoidance or reaction time.
If you use waymo there is evidence that every single speed bump that they drive over is premapped. If the speed bump is not premapped, the car won't slow down for it. There's evidence of waymos driving over speed bumps at hilariously incorrect speeds even though that are ridiculously visible.
If you don't have HD maps, you can't sync your lidar to the HD map and get this level of geolocation precision. You need this to accurately slow down for objects that you have issues with identifying. The argument with HD maps it provides a level of localized knowledge about everywhere you drive that you don't need to know everything about every road or intersection you encounter, you get a higher level of redundant safety in poor visibility scenarios (like snow/rain), and then basic driving behaviors become distilled to information that can be presented in map format. Also with GPS you can be 20m off from your actual location which can cause issues with thinking you're on a road you're not, accidentally being on the wrong side of the road, missing a turn at freeway speeds, thinking you're in the wrong intersection, etc.
The other issue is not having HD maps with this much driving information is that the performance does not scale to other countries. Waymo, for example is pretty easily able to handle RHD countries like england/japan/australia, whereas FSD performance is pretty bad there. Presumably also in europe it is much easier to tailor the driving to local regulations or to follow very specific rules like pickup and dropoff requirements at an airport.
The argument against not using HD mapping is it is not possible to achieve a scalable safety level without operating this way.
Huawei ads 5:
https://www.bilibili.com/video/BV1S...ck&vd_source=0e066e8af14fb39cf344050f887d347d
Chinese V13:
https://www.bilibili.com/video/BV1K...ck&vd_source=0e066e8af14fb39cf344050f887d347d
Cracked na v14.2:
https://www.bilibili.com/video/BV1PHpE6nEfd/?spm_id_from=333.1387.upload.video_card.click
Xpeng vla 6.3:
https://www.bilibili.com/video/BV1d...ck&vd_source=0e066e8af14fb39cf344050f887d347d
Look how bad these cars are performing.
Something people also don't know is mobileye own a pretty ridiculous and broad patent preventing cars from reading road signs.
Waymo mostly does not read road signs, and neither does tesla. Tesla seemed to have invented an alternative method to read speed limit signs, but I believe every other automaker on the road licenses mobileye's speed limit detection.
if you have an HD map this is much easier than a car without HD map to get around this limitation.
There are other details like tesla pushes out updates to FSD sometimes 3 or 4 times a week to test changes to the neural network. I believe china restricts update frequency and requires approval for new updates. This would hinder the speed you can iterate and fix issues.
For other information on the charging.
Waymo staging lot in austin uses natural gas charging with 40% efficiency. Puts their equivalent MPG around 19mpg and they charge at least 2x per day
Tesla uses unpaved lots with no charging, because they only need to charge every 2 or 3 days. They charge at superchargers overnight.
If lidar is so key to good ADAS, then why has Volvo abandoned it (for now). I have always wondered just how much Lucid actually uses the current lidar on their cars. I have a feeling it was more of a “lidar is getting cheaper so lets put one on our cars and hope we figure out how to optimize it eventually”. Putting lidar on cars also helps justify the very high DDP and DDP2 upgrade costs even though DDP currently is about a good as similar systems from competition that cost 1/3 what Lucid charges for DDP(2).
The key will be when (if) the NVIDIA Alpamayo goes live in Lucid. Hopefully we will have better data in another year or so when more consumer cars with lidar based point-to-point systems start racking up miles on the roads.
Well if ev’s were so great then gm, ford, and stellantus would not have reduced their commitment to them
So we may as well just go backwards.
The point is that companies do all kinds of things for reasons not always apparent to outsiders.
It's marketing. They put it in and convince you the lidar is the reason they'll have self driving where others will fail. Consumers eat this up. They believe rivian has some advanced self driving hardware when the memory bandwidth (the real limiting factor) is just as bad as everything else on the market.
There is also a technical answer that in the future if some generic AI gets ridiculously efficient and you can run on a very weak computer, then more sensors could possibly unlock self driving in a car that could theoretically not be sensor limited
in the case of say tesla if there is a camera blind spot or camera weakness that can never be overcome
To me this logic is nonsense as you can always manufacture a car faster than you can unlock self driving for consumers.
If I recall correctly it was because their supplier, Luminar, was having issues. Luminar has more recently declared bankruptcy.
Lucid uses Robosense LiDAR from China in the Air. I am not sure if is the same for the Gravity or not.
Yes but even without that, it was never being used
As I keep repeating there is zero evidence of any car, anywhere in the world having a solid state lidar that has meaningfully prevented an accident with something that is hard to see, or really that these lidar do anything at all
The only cars that have ever been used for robotaxi thus far have 360 spinning lidar
Back again? Using just cameras and no redundancy is a fools errand!
Great photo in Dallas where the cybercab hasn't launched service yet. I'm sure they get excellent range being that they are just sitting there waiting for service to begin.
LIDAR provides a usefully different set of sensor data, but sensing is not the difficult problem in autonomous driving. Software that can make sensible driving decisions is the hard part. I don't know why Volvo abandoned it, but Volvo isn't known for being a serious player in autonomous driving, so they may have just decided to save a few bucks and eliminate a sensor that their software wasn't particularly capable of taking advantage of. When Alpamayo based autonomous vehicles comes out, I doubt we'll learn much at all about the benefit of LIDAR sensors. The data that would really shed light on that question is likely to be a closely held trade secret. As we see from mobada's relentlessly pro-FSD posting, there will doubtless be arm-chair engineers who think they know a lot about the inner workings of the autonomous driving stack, and they'll largely be full of BS. You'll be able to identify the BS'ers by how confidently they assert definitive knowledge of autonomous driving systems.
