Issues with ambient lighting in air gt
ilushka85
Lucid Air GT
Recently my 2025 air gt started having issues with lightning inside. When I get in the ambient lights set themselves to white despite the theme. The roof light is also off. It takes toggling brightness and theme to get color to change. And only way to fix roof light is an air reset. Then the roof light comes on again. But next time I get in the car the same issue happens again.
Contact service. This is the first I’ve ever heard of this, so something is wrong.
I’m waiting since last week for service to reply to emails about my connected charger stopping to work. Service is unresponsive.
I find the best results when I text them or call them. Email sometimes seems to disappear.
DId you manage to get this sorted? I have the exact same issue. A couple of times they have worked but mostly i get the same symptoms. White lights instead of theme and non responisive to theme inputs. I haven't contacted service yet because I just took delivery of my car and am working through the learning / user error curve before reaching out.
The same thing is happening with the ambient lighting on our 2025 Air GT after we updated to version 2.5.4. The ambient light in the glass canopy spine won’t turn on at all. Took it to Service and there was nothing they could do to fix it. They told us it will require another software update to fix the issue. Has anyone else been told this?
Has this been resolved for anyone? I just took delivery of my GT and having the same issue. Also, is there any way to have the windows close a little more. Getting sound when driving that would suggest it’s not closing fully.
It looks like software update 2.5.4 Fixes the problem
Do a search on wind noise.
Unfortunately, it did not fix ours. The update actually made it worse as the ambient light in the glass canopy spine stopped working altogether after the Lucid Tech updated the software on our 2025 Air GT to 2.5.4. We just updated the software to 2.6.0 but the ambient light is still not working. Any suggestions?
I had the same issue when I got my 2024 Air Touring in Nov. Roof and sides weren’t working and the themes wouldn’t change. Brought it into service for a problem with the rear windshield not defrosting and they found that in guest mode, the ambient lighting worked. In the main profile it didn’t for some reason. There was an update in Dec/earlyJan (can’t recall exactly when) that specifically fixed this one problem and it’s worked ever since in the main profile. I’m doing the newest update now so hopefully it won’t revert back to not working. Maybe try the guest profile to see if the ambient lighting works that way?
Did you do a hard reset for the car? try that multiple times. I had to do that.. otherwise, you might need to take it to the shop
That's too bad, really hoping 2.6 fixes my ambient lighting. The only time I've gotten the roof strip to function, the entire sound system stopped working (including blinkers).
I do t have the glass roof (no ceiling strip) and just the purluxe interior and since I picked it up a month ago I have only ever had white ambient lights. I assumed maybe the had penny pinched my spec in 2025 and the themes now only change the screen color… maybe I’m wrong and they should be changing color and u have the same issue as everyone else? Car arrived with 2.5.4…
Only cars with the glass canopy or leather interior come with the extended configurable interior ambient lighting.
That’s what I assumed (very unclear on the website configurator) but fine with me as I would have set it to white anyway…
I can report having this issue with ambient lighting and unresponsive themes.
I have yet to reach out to SC because I view it as a minor thing and it would be my first ‘thing’, the car doesnt even have 1k on it and I am still wanting to drive it all the time everywhere, it’s phenomenal.
Didn’t notice the ambient lighting issue until the first night drive but for mine, the light above the arm rest on passenger side has never been on, works fine on the driver side, otherwise the lights on the sides of the dash only work after a hard reset, then, after a sleep, they don’t work at all. All the rest of the lights work fine but, after a sleep, they reset themselves to white, regardless of the theme setting. In mine, even though at first, there is no response when changing themes, I can play around by switching them around and turning them on/off to eventually get them back working and responding, but then, after a sleep, they go back to white and initial unresponsive state.
Still on 2.5.4.
