Is this something that needs calibration, or does this happen to everyone? If I put the car in "stop mode: hold", when you come to a stop (or you're creeping), the brake pedal kicks back similar to how ABS behaves. Also pretty noisy as the brakes grab/release constantly while creeping.
The pedal thing seems like something that could/should maybe be calibrated.
Kind of wished there was a mode more similar to what I had in the Taycan, which is roll mode, unless you press the pedal all the way and then it engages hold. Probably a solution to this problem where the actuator that's handling the pedal hold if you try to threshold it makes it kick back like this.
