Gravity Speedometer of off
boydracing
Park City, UT
new Subaru and Gravity
Gravity DE Number
260
Saw some stuff on the Air back in 2024 for a speedometer error. I guess it is the same with the Gravity too. I go 30 mph and actual speed is 28 mph. I verified this on local RADAR in neighborhood as well as handheld GPS speed. I am a 21"/22" wheels Gravity. this would equate around 7% over the actual. Can Lucid fix this? I mean, obviously this should not be a big deal. It is a big deal when it comes to warranty life.
Hi
Almost all manufacturers do this to avoid legal repercussions for speeding
Personally, I want my speedometer to be as accurate as possible. I hadn't thought about the discrepancy prematurely ending the warranty. Considering how expensive out-of-warranty repair costs probably are for a Gravity, that seems like plenty of reason to send the vehicle to a service center for correction.
The speedometer operates separately from the odometer so no worries about early warranty expiration. Also, every Porsche I’ve owned has read 3-4 mph faster than actual - always. My Tesla seems dead on with radar and GPS but it definitely is not uncommon for the speedo to read a little fast for a lot of cars.
There are many threads on this. It is intentional, and the law allows for up to a 15% discrepancy iirc. Lots on the forum about this for the Air.
So you are referring to 49 CFR §393.82? 15% is a pretty big sway from the national standard of 10% +/- at 50 mph. Oh, and yes, 7% is well within the national limits.
I did hedge with “if I recall correctly,” and apparently I didn’t. But that subsection of the code only applies to commercial vehicles (if I recall correctly, lol).
The other two relevant sources are:
  • European Union (EU) Rules: Mandate that speedometers must never indicate a speed lower than the actual speed, allowing for some error on the higher side (e.g., up to 5% plus).
  • Society of Automotive Engineers (SAE) Standard J1226: Recommends manufacturers calibrate for accuracy within 2% (plus/minus) or 4% with a bias towards reading high.
...but it doesn't. YMMV
My 2025 AT reads 1mph slow at 70 (Relative to Waze. Car at 71, Waze reads 70)
My previous BMW was reading 3.5-4mph slow at 70mph, also relative to Waze reading.
In that example, your car is actually reading slightly fast, not slow.
I guess the standards say if your speedometer is accurate to within 5+/- mph @ 50 mph - GTG. Except for my Datsun Roadster, no other car I owned was off by more than 1 mph. I guess I was lucky. At least my example of the Gravity is accurate within 2 mph.
The 1969 Datsun Roadster was highly optimistic. If I was doing 70 mph - actual speed was more like 65 mph. I think that had to do with something I did.
