Gravity smallest wheel size?
mackmoot
Anyone know the smallest wheel size that'll work on a Gravity? I'm assuming 19", based on nothing, just a guess. 18" would be awesome...
Looking to square (de-staggered) sizes and get maximum sidewall height for winter (and/or gravel roads).
How about bolt pattern, same as Air? (would the 19" Air wheels work on Gravity?)
There's been some prior discussion of this, but no definitive answer. Given that the smallest factory wheel setup is 20/21, and the brakes fitted to handle the weight of the vehicle, it seems quit possible that smaller wheels just won't fit. If you really want to do this, seems like it would be worth taking the car to a wheel dealer with a wide inventory, and letting them experiment with what does or doesn't fit.
I'm wondering what you're thinking about tire width with squared wheels? Reducing the contact patch on the rear wheels doesn't seem like a great idea given how much power the vehicle has. But I don't know that similarly wide tires will fit in the front, especially when the wheel is turned all the way left or right.
For winter, I don't personally think that taller sidewalls makes a difference to me. But I know less about off-road tire considerations. Lucid did demonstrate their off-road Gravity X concept earlier this year. Maybe try calling them up and seeing if they'll tell you what the tire setup was for that? Or maybe there's press coverage somewhere that says. The Lucid page just says 21/22” all-terrain tires.
I am going square 22s in November, staggered tire.
Gravity wheel spec for bolt pattern and bore in the same as air but no guarantee the brakes will clear or that the Air wheels have enough weight capacity.
5x120 bolt pattern
64.1mm wheel bore
