Anyone else notice their GGT distance reading under 300 miles at 80% charge. Just checked mine and it's reading 282 at a little over 80% charge. Does anyone know if the app shows dynamic range even though it's listed as rated range?
The app also shows the dynamic range number as the rated range for me sometimes after charging to 80%. It eventually updates to the correct rated range. As long as the car shows the correct numbers, I'm fine.Anyone else notice their GGT distance reading under 300 miles at 80% charge. Just checked mine and it's reading 282 at a little over 80% charge. Does anyone know if the app shows dynamic range even though it's listed as rated range?
I prefer the rated percentage anyways, which is showing correctly in the app.Thanks for the info, I just checked when I got home and you're correct it's showing the dynamic range in the app instead of the rated range
There is no "rated percentage," I believe the Gravity options are:I prefer the rated percentage anyways, which is showing correctly in the app.
Yep.There is no "rated percentage," I believe the Gravity options are:
Percentage SOC
Rated Range
Dynamic Range
