Other than a dramatic reduction in the frequency of error warnings and messages, I have more or less all the same bugs I've been complaining about since I got the car.
- Fob works correctly to unlock the vehicle on approach about 25% of the time. 75% of the time I have to wait. These days at least it does eventually open with the fob (ie no card tap or app unlock required about 98% of the time) but only after I walk around near the vehicle for 5-20 seconds, pushing the unlock button, or walking closer to the rear driver side door, where it seems to have better recognition of the key.
- Fob fails to lock the vehicle on exit about 50% of the time. I get the notification on the app that the door isn't locked and I have to do it that way.
- Hands-free calling is unuseable garbage.
- Key not inside vehicle fails to start the car still rears its head, if rarely. Maybe 1 in 30 drives.
- I still get warnings for "Sensors Blocked" and "Dream Drive Unavailable" from time to time, irrespective of weather conditions. Happened more in the snowy weather, which maybe I understood (road salt) but also happens on sunny days, clear mornings without bright sun, who knows. This is definitely a lot less frequent than it was at first, and I don't get some of the other errors that would pop up, but I'd say this issue is not 100% squashed yet.
- I have an airbag fault detected light that pops up every once in a while. When I reported it to swfeedback they recommended service. Service could not replicate the problem and therefore didn't repair anything.
- Easy entry/exit seat position is like playing roulette. Sometimes it moves back when I get in, sometimes it doesn't move at all, sometimes I swear it moves but not to the right place. I'd say it gets it wrong about 2/3 of the time. Sometimes when it moves to the wrong place or doesn't move at all I can go into the seats submenu and select "Restore" to make it right, but sometimes the restore button is greyed out.
- "Traffic Cleared" pops up at random times, probably every other day or so, when stopped at a traffic light or stop and go traffic - but never when the traffic has actually cleared.
- The other day, I got a new one - if only for a second - a big red "Air supension unavailable" flashed up in the center clearview cockpit. It was gone within 2 seconds, so I barely got to read it. Not sure what that was about.
My charge port door is getting more finicky. There's a little "button" with a collar/"wings" that rotates 90 degrees when you press it to mechanically grab the door and hold it shut when it's closed, and again when you release it to let it go. The rotating collar seems to get stuck about 10 degrees away from where it is supposed to be, making the door not want to stay closed, or worse, needing a bit of a hard tug to get open. When closing, I can manually fiddle with it, putting it in as "vertical" an orientation as I can to get it to hold when I press the port door shut, but the tugging makes me nervous that one of these days the plastic piece is going to break and I'm going to be driving around with duct tape to hold the door shut. That's gonna be a good look! Mobile service shrugged the problem off during the winter, saying he couldn't replicate it, and I forgot to mention it on my last in-garage service appointment. I'm kicking myself now because it suddenly seems to have gotten worse.
Does anyone else find that the lane departure warning is hyperactive? Sometimes I would swear I am too far to one side and it will tell me I'm too close to the other. It's almost impossible to drive on an exit onramp and not have it rattle on me. Maybe I'm just a sucky driver, but I don't think so. I've had lane departure warnings in other cars and not had this issue.
