Gravity and Tesla Wall Connector (Gen2 not supported, Gen3 works)
Zzzt
Wisconsin
Gravity, Tesla X, Y, 3
Gravity DE Number
117
I brought my Gravity DE home and was surprised to encounter charging errors when I plugged it into the Tesla Wall Connectors I have used for my Teslas for years. To make a long story short, Lucid does not support the Tesla 2nd Generation Wall Connector, but does work with the Tesla 3rd Generation Wall Connector. Note that these are both for Level 2 AC charging with Gen2 debuting in early 2016 and Gen3 in early 2020. Beyond the obvious fact that it would be nice to support the Wall Connector you already have (if you've owned a Tesla since before 2020), Gen2 supports 19.2kW (80 Amp) charging while Gen3 is limited to 11.5kW (48 Amp). Having to get a new Wall Connector to charge Gravity is unfortunate, but having that new Wall Connector charge slower than the old one is irritating.
Just an FYI for folks who have been driving electric for a long time.
If anyone has multiple Gen3 Wall Connectors that are sharing a circuit, can you comment on how load sharing works with Gravity?
I will have to give that a try. Thank you for the link! I can see why "legacy" mode might help, but it is very strange that toggling that and switching to 56 Amps maximum makes it work.
My Gen2 Tesla EVSE shares a circuit with another Gen2 so I will need to test to see if this has any impact on load sharing.
The above thread is a little bit confusing, but the general take away is that the Tesla gen2 Wall Connector doesn't work at 80A. I'm currently charging my Lucid Air on gen2 Tesla Wall Connectors using a Teslatap Mini 80A. I would assume I can continue using this setup on the Gravity and insert the CC1 to Tesla adapter that Lucid provides for the Gravity. I have a friend in town that has a Gravity and I'll ask to try it on that.
I'll jump in. don't need Legacy mode. Just need to move the amperage down. Something in the 80A charging communication that's the problem. I also use a Teslatap mini 80A for my Taycan, works fine with Gen2 @ 80As. but it never really pull anything more than 11kWs anyway. So no point on the 80A, I was just thinking maybe future compatibility so I don't have to buy another Teslatap. I was really hoping that Gravity will take advantage of the 80A. But at 56A. Gravity is pulling 13kW, so I feel like it can do 80A. All the new Tesla can only do 48A max anyway. So Gen2 80A setup only works with the older Tesla with dual chargers, each at 40A. I'm crossing my fingers that maybe future software updates will unlock this and do 19.2kW, then my Gen2 will really shine.
The Gravity have NACS. you don't need a Teslatap. Just plug the Tesla NACS connector directly in.
-iThinkEV-
To clarify, I asked my service center why the Gen2 EVSE wasn’t working and they said it wasn’t supported, but the Gen3 should work. This despite the fact that both have the NACS form factor as does my Gravity’s charging port and I thought they all implemented J1772 for signaling. However, some googling suggests that Gen2 doesn’t actually do J1772? I’m confused.
Gen2 does J1772 fine. I use a Teslatap and it charges my Taycan for the past 3 years.
I'm currently charging my Gravity with said Gen2 wall charger set to 56A. All 4 of my EVs (3 Tesla, 1 Taycan) charges from this Gen2. They all draw 48A, and Gravity draws the full 56A. That's why I'm hoping future updates will allow it to pull 80A.
-iThinkEV-
Minor correction: you will use the J1772 to NACS adapter. The CCS1 to NACS is only for DCFC.
I have been using gen2 80A Tesla wall connector with my Air with J-1772 adapter for the past 3 years flawlessly.
I sure wish I could use my Gen2 Tesla Wall Connector at 80 Amps with Gravity; however, it doesn't work and when I raised it as an issue with my service center they said it wasn't supported. I hope to rotate the configuration dial in the Wall Connector to reduce the maximum Amperage this weekend and see if that works.
Given your experience I could also try a NACS->J1772->NACS adapter, but that seems like a hack...
Would it work if you dial down the amperage from the Gravity screen instead of the wall connector?
You should experiment your plan of NACS->J1772->NACS adapter.
alright, I'm going to be brave and try this over the weekend, and see if I blow anything up.
Going to move Gen2 back to 80amps, use my Teslatap 80A adaptor, then the NACS adaptor from the Teslatap.
-iThinkEV-
I would be shocked if that worked, as those are passive components. (Or, you might be... shocked.)
Actually the TeslaTap Mini, for example, has special bypass circuitry. See this explanation from Grok:
The TeslaTap Mini and other TeslaTap adapters work reliably with high-amperage charging due to a specialized bypass circuit that ensures compatibility between Tesla’s NACS (North American Charging Standard) connectors and J1772-equipped electric vehicles (EVs). Below, I’ll explain the role of this circuit, why it’s critical for high-amperage charging, and why some adapters fail without it.
Background: NACS and J1772 Standards
  • NACS (Tesla’s Connector): Used by Tesla for Level 1 and Level 2 AC charging (e.g., Wall Connectors, Destination Chargers, Mobile Connectors). It supports high currents (up to 80A on some Tesla chargers) and communicates with the vehicle using a proprietary protocol.
  • J1772 (SAE Standard): The standard AC charging connector for most non-Tesla EVs in North America, typically supporting up to 48A (sometimes 80A for certain vehicles like the Ford F-150 Lightning). It uses a different communication protocol (Control Pilot signaling) to negotiate charging parameters.
  • Challenge: The two standards use different physical connectors and communication protocols, so an adapter must bridge both the physical connection and the signaling to enable safe and efficient charging.
Why Some NACS-to-J1772 Adapters Fail
Many cheaper or poorly designed NACS-to-J1772 adapters are "passive" devices, meaning they only provide a physical connection between the NACS plug and the J1772 port without actively managing the communication protocols. This can lead to issues, especially at high amperages:
  • Communication Mismatch: Tesla chargers use a proprietary handshake to verify the vehicle and set charging parameters. J1772 vehicles expect a standardized Control Pilot signal. Without proper translation, the charger may fail to initiate charging or limit current to a low value.
  • High-Amperage Stress: At high currents (e.g., 40A–80A), poor electrical contact or inadequate components can cause overheating, voltage drops, or arcing, potentially damaging the adapter, charger, or vehicle.
  • Safety Protocol Gaps: Tesla chargers rely on specific safety signals (e.g., proximity detection) to ensure safe operation. Passive adapters may not fully support these, leading to unreliable or unsafe charging, especially on high-power Tesla Wall Connectors (up to 48A or 80A).
For example, users have reported issues with adapters like the Lectron NACS-to-J1772, where charging fails or requires extra steps (e.g., turning the car on/off) due to improper protocol handling.
The TeslaTap Mini’s Bypass Circuit
The TeslaTap Mini (and other TeslaTap adapters) includes a specialized circuit that addresses these issues, ensuring reliable high-amperage charging. Here’s how it works:
  • Protocol Translation:
    • The TeslaTap Mini’s circuit actively translates Tesla’s proprietary communication protocol to the J1772 Control Pilot signal. This ensures the Tesla charger recognizes the non-Tesla EV as a valid device and negotiates the correct charging parameters (voltage, current).
    • Without this circuit, some EVs (e.g., Hyundai Ioniq, Kia EV6) may fail to initiate charging because the Tesla charger doesn’t receive the expected handshake.
  • High-Amperage Support:
    • TeslaTap adapters are designed for continuous high-amperage loads (e.g., 40A, 50A, 60A, or 80A, depending on the model). The 60A TeslaTap Mini, for instance, supports up to 15 kW (60A at 250V), while the 80A version supports up to 20 kW.
    • The circuit ensures stable current delivery by maintaining proper electrical contact and managing signaling to prevent throttling or interruptions. This is critical for high-power Tesla Wall Connectors (e.g., Gen 2 or Gen 3, which can deliver 48A–80A).
  • Safety Features:
    • The bypass circuit maintains full compatibility with Tesla’s safety protocols (e.g., proximity detection, ground fault protection) and J1772 safety standards, reducing the risk of electrical faults or overheating.
    • The adapter includes O-ring seals for weatherproofing (IP67 rating) and high-quality pins to ensure secure connections, minimizing resistance and heat buildup during high-amperage charging.
  • Compatibility with All U.S. EVs:
    • The circuit makes the TeslaTap Mini compatible with all U.S.-built J1772 EVs, including those with oversized ground pins (e.g., Rivian, Toyota RAV4). This universal compatibility is achieved by dynamically adjusting to the vehicle’s charging requirements.
Why the Circuit Matters for High Amperage
High-amperage charging (40A–80A) places significant demands on the adapter:
  • Thermal Management: High currents generate heat, and poor adapters can overheat, leading to failure or safety risks. The TeslaTap’s robust design and circuit ensure low resistance and proper heat dissipation. Users report minimal heat buildup compared to cheaper adapters.
  • Stable Communication: At high amperages, the charger and vehicle must continuously communicate to adjust current and monitor for faults. The TeslaTap’s circuit ensures this communication is seamless, preventing dropouts or reduced charging speeds.
  • Vehicle-Specific Limits: Some EVs (e.g., Kia EV6) limit AC charging to 40A–48A, while others (e.g., Ford F-150 Lightning) can handle 80A. The TeslaTap circuit adapts to the vehicle’s onboard charger limits, maximizing performance without exceeding safe thresholds.
Comparison to Other Adapters
  • Lectron (48A/80A): Often cheaper (around $100–$150), but users report inconsistent performance, especially with E-GMP vehicles (Hyundai/Kia). The lack of a sophisticated bypass circuit can cause charging failures or require manual intervention (e.g., waiting 30 seconds or power-cycling the car).
  • A2Z Stellar Plug (80A): A newer competitor with a good reputation, supporting up to 80A and featuring a dual temperature kill switch for safety. It likely includes a similar protocol-handling circuit, but some users note a tight latch that may loosen over time.
  • Generic Amazon Adapters ($50–$80): Often lack safety certifications and active circuitry, making them unreliable for high-amperage or frequent use. They may work for low-amperage charging (e.g., 16A–24A) but risk failure at higher currents.
Limitations and Notes
  • Not for Superchargers: The TeslaTap Mini is designed for AC Level 1/Level 2 charging (e.g., Tesla Wall Connectors, Destination Chargers) and is not compatible with Tesla Superchargers, which use DC fast charging and different protocols.
  • Cost: TeslaTap adapters are pricier (e.g., $260 for the 60A Mini, $170 for the 50A) compared to Lectron or generic options, reflecting their advanced circuitry and build quality.
  • UL Certification: No NACS-to-J1772 adapters, including TeslaTap, are currently UL-listed due to the lack of a specific UL standard for these devices. However, TeslaTap uses UL-certified components, offering a higher degree of safety assurance.
Conclusion
The TeslaTap Mini’s bypass circuit is a key differentiator, enabling reliable, high-amperage charging by translating Tesla’s NACS protocol to J1772, maintaining safety protocols, and supporting continuous high-current loads. Cheaper adapters often lack this circuitry, leading to compatibility issues, reduced charging speeds, or safety risks, especially at higher amperages. For users charging at Tesla Wall Connectors or Destination Chargers (up to 48A–80A), the TeslaTap Mini (60A or 80A versions) is a robust choice, particularly for EVs capable of high AC charging rates. For occasional use or lower-amperage scenarios (e.g., 16A–24A), alternatives like the A2Z Stellar Plug may suffice, but TeslaTap remains the gold standard for reliability.
Duplicating my reply https://lucidowners.com/threads/not...r-but-works-with-tesla-evse.12656/post-297455:
Thanks to you guys, I'm back in business with my gen 2 Tesla Wall Connector. 56A didn't actually work for me, I had to step down to 48A. Here's how you do it:
0. Turn off your breaker.
1. Remove the bottom screw with a T10 screwdriver.
2. Pop off the cover using a flathead screwdriver. There are several tabs on each side. Tesla actually cracked my cover when installing in 2019, so be careful.
3. Remove the main screws with a T20 screwdriver to expose this:
4. Put the dial into position 9 for 48A:
5. That's it, put everything back together and flip the breaker back on, then charging should work.
From what I can tell from the NACS standard doc there is nothing that limits the voltage/current. To quote:
The North American Charging Standard shall specify no maximum current rating. The maximum current rating of the inlet or connector shall be determined by the manufacturer, provided that the temperature limits defined in section 8 are maintained.
and
ICHG is the power source output current. The maximum output current shall be limited by the power source capabilities andt hermal limits of the system.
But, Wikipedia states:
However, in typical configurations, NACS provides up to 48 amps of current at 240 V (the standard residential voltage of the North American split-phase electric power system), yielding 11.5 kW.
It's disappointing that Lucid doesn't have the code/circuitry to see 80 amps and just ask for less.
This means I'll have to program one of my Gen2's to provide 48amps, and hope that it doesn't prevent the other one from achieving 70 amps, which is good to have for my Roadster.
The level 1 and level 2 charging in Lucid is J1772 compatible. The Lucid wall connector is J1772 and will do 80A and it works fine on the Gravity.
The Tesla gen 2 wall connector does load sharing, and possibly that is causing the problem with it not properly sending a signal that the Lucid will understands. But the pilot signal that indicates the current available is a PWM signal that spans +/-12V. The duty cycle for 80A is 96%, so maybe that is not properly detected by the Gravity. Also, the problem could be that the pilot signal on the Gen 2 ramps up the current indication duty cycle before it reaches 80A.
In any case, the Gen 2 works fine in the Air at 80A, so obviously Lucid knows how to handle it.
Interesting, I didn't know gen 2 charges the Air at 80A, except with an adapter, right? There's hope after all then.
I started a case with Lucid about this and will bring it up. Maybe they'll find some time to sort it out properly once the car is more stable.
You need a Tesla to J1772 adapter for the air. I mainly use the TeslaTap mini 80A, but I have several other Chinese 80A adapters that I bought from Amazon which work fine. They are mostly less than $50, whereas the TeslaTap is over $300. I have a Gen 1 Tesla wall connector I run at 80A at my vacation house and use the Chinese adapter (EvDance).
When I get my Gravity, I’ll test and see if the Gen 1 works. The Gen 1 will also work up to 270V (used at commercial locations), although I only tested it that way on a 2012 Model S (21.6kW).
OK, so I got to drive a Gravity to my house during a test drive today.
I set the Gen-2 Wall Connector to 48 amps - and it charged! Pulling around 30 amps though (Gravity at 125 miles of range).
I set the Wall Connector to 56 amps - and it charged at 40 amps.
I set the Wall Connector to 64 amps - and it charged at about 30 amps. Weird, eh?
I would have tested more, but I wanted to get driving.
I have two Gen-2 connectors on a single 100amp breaker. You can only change the amperage on the "Master" - the others need to be set to Slave if they're on the same breaker.
So while not ideal, this does let me share 56amps between our two EVs if one of them is a Gravity.
