- Mar 22, 2022
- Air GT Black/Tahoe/19"
How long ago were your latches replaced, like what version? They’re on 8 now. Mine is MUCH better, closes very smoothly.
I’m not sure but they were replaced roughly 1 month agoHow long ago were your latches replaced, like what version? They’re on 8 now. Mine is MUCH better, closes very smoothly.
One fix for me and haven’t recurred the issue. I think I use frunk 80% of time, 20% of time trunk.Reviving this thread..
How many of you use your frunk on a regular basis?
I've had my Frunk realigned and latch replaced. A few months ago.
The issue is back and when I open and close the frunk, it shows it didn't close properly. Technician is coming out again.
But this is definitely an ongoing problem.
Same here. While HV battery replacement i asked them to repair the frunk failure to open (trying to go up, quitting, going up and quitting again).Reviving this thread..
Yeah, the solution is to rest your hand on the latch and give it a little pressure as it latches. And that's what I'm doing until the technician comesSame here. While HV battery replacement i asked them to repair the frunk failure to open (trying to go up, quitting, going up and quitting again).
Now, the frunk opens up and closed with a visible misalingment, left closes first then the right one follows.
The pisser is that while it is visibly closed i can't drive the car because the front screen shows the frunk is still open.
I get that issue with the rear trunk... It opens 3 to 4 inches, stops. Press the button again goes up 3 to 4 inches and stops... Finally makes it to the top and then i push to close and it wont. Have to manually close it. They replaced the latch and claimed software bug. This is using the open/close button on the trunk. If i open from the panel, it goes up and down. Getting annoying.Same here. While HV battery replacement i asked them to repair the frunk failure to open (trying to go up, quitting, going up and quitting again).
Ugh.... Thanks!!! Frustrating! I'll give them another ring to schedule another appointment. Their corrections were:This is NOT a SW bug.
Take it back in, and tell the service people to fix it.
Update.. Technician came out, realigned it. Left.Yeah, the solution is to rest your hand on the latch and give it a little pressure as it latches. And that's what I'm doing until the technician comes
