From 21" to 20" and LOST range??
DrDrama84
Looking for some advice for my 23 AT.
I recently switched from oem 21" wheels/tires to 20" aftermarket forged square setup, looking to increase range with a better look. Wheels are 20x9.
When I bought the car, I was averaged 3.2 m/kwh, but had the battery replaced with warranty a few months ago and my efficiency moved up, close to 3.4.
I went with Bridgestone Re980 AS+, and admittedly did not realize I would lose so much on the range by switching to all-seasons, but also thought the lower weight would help offset any tire range loss.
Based on listed weight of tires 30 lbs and wheels are 27.4, I am 4 lbs lighter per wheel in the front, and 10 lbs lighter in the rear compared to 21s.
I only have about 700 miles on the new tires but am down to around 3.1-3.2 mi/kwh.
So I have a few options.
1 - suck it up.
2 - I bought the tires from tire rack, 90 day try it guarantee or whatever. I can replace them with bridgestone/Firestone summer tires and then hope to regain my range. There's no guarantee that'll happen even with summer tires.
These tires are 27 lbs so I would have additional weight savings as well.
3 - see if anyone who isn't as anal about range is interested in buying them and going back to oem.
My preference is #2 but if I don't get my range back, that would be beyond annoying.
Thank you for reading and your input.
Not sure where you live but temps have been dropping many places and range will go down accordingly. Maybe this is a factor?
I'm in Dallas. We've had a few cold mornings, but most days end up in 60s-70s. So yes, I considered that but even the colder mornings didn't change the range much.
