First time charging at a true V4 Supercharger (Garden Grove, CA)
RandomDesign
San Diego, CA
2026 Gravity GT
3Q9SEQEI
Preconditioning said max speed would be 340 and I almost immediately hit 339 starting from 23% SoC. It dropped into the mid 200s pretty quickly and then the 170s once I hit 50%.
Nice to see the V4s finally showing up. I’ll post the final charge curve later.
25 minutes to go from 23-80%? Is that good? Genuinely asking…
It is for a battery of this size, but I often find that time it gives to 80% is often overestimated and it takes a few minutes less.
What are you doing up in GG? Disneyland en route to the Owners Event tomorrow? 🤣
No Disneyland, passing through on the way to Pasadena for the event tomorrow. I saw that the 500kW V4 opened here 5 days ago so I timed it to try to get to GG around 20%.
Not the most scientific of tests but I wanted to try the V4 as long as I was there. In the end it actually took just about 23 minutes to charge from 23% to 80%.
65 kw in 23 minutes is OK. But nowadays newer models have that in 15 minutes or so
So still a good charge but not too of the line anymore.
At least in the US, there are not many EVs at all that can put that much energy in that quickly. And reaching an 80% charge in 23 minutes from about 20%? Less than a handful can do that. Gravity still has one of the best charging curves out there right now and is still top dog until the Cayenne EV releases likely.
Which vehicles in the US are better? I know China has megawatt flash chargers that can charge in 5-10 minutes, but none of that is available in the US.
From what I’ve seen, the Lucid Gravity is still top dog outside of China. @RandomDesign’s data matches the detailed charging curve analysis from StateOfCharge:
2025 Lucid Gravity GT DC Fast-Charging Analysis: 400-kW Monster​
The Gravity edges out the Porsche Taycan in miles per minute (the Taycan has a smaller battery) but comes close:
Porsche Taycan vs Lucid Gravity: Who Really Has the Fastest EV Charging?​
I agree with @9point81 that the Cayenne may finally dethrone the Gravity, but not by much. The Gravity will still be among the best (Olympic-level gold vs. silver).
Like to see how this works on an Air when they enable higher voltage
My L3 top speeds are crimped due to 0 L2 charging.
I went 27-81% in 26 minutes. Peak rate was 239kw
NY Gravity Charging.
@Lycra lives in the EU, where faster-charging Chinese vehicles are available.
It'll work exactly the same as today's 350+ kW CCS stations.
OK.for example the BMW new class ix50 does 75kwh in 20,minutes. Of course not to compare with gravity. I mean just from charging perspective.
Correct.not just chinese cars. The new BMW neue class is amazing considering charge speed.
Comparison
Ok… that car is not available in the US right now. That car is coming later this year, along with the Cayenne and both expected to be charging beasts. Right now, Gravity still holds the crown. It was always going to be a temporary thing, so they have it for now but we all fully expect it to be surpassed. And that will still leave a handful of cars in the US that can onboard as much energy as quickly as Gravity can.
Comparison
The EX60's charging curve is quite good as well. But it won't come to the USA until 2027.
We do already have in Germany the denza which charges in 9 minutes 100%. It goes to 80 in 6 minutes and charges with 1 mega Watt.. That is crazy. And byd opens 3000 x 1.5megawattt chargers in Europe. Some are in Germany already working.
Sigh…and Germany is so beautiful too (was there last year) and folks make sense and have decency and open to Chinese EVs…sigh….if I could convince the wifey…
