I got 1.6 (and still rising) towing an open aluminum car trailer with a sports car on it, but calculated from usage was getting 203 miles/fulll charge. Total towed weight about 3400 lbs but also 8 wheels/tires and a LOT of tools in the Gravity (tires alone approximately 320 lbs). Based on actual usage, >180 miles for first leg, and >140 miles for each additional leg assuming charging with 10% of charge remaining and charging to 80%. That was my plan for the long tow, but I ended up stopping at almost 30% remaining and by the time I bought a rushed lunch the car had charged to >90% (15 minutes -- 360 kW charger). If your load has low wind resistance, you should have great range.
I took the tire rack off my trailer but will do a tow in the next couple of months with the tire rack on and loaded, to see how much of a hit my range gets with that significant increase in wind resistance (the tire rack holds the tires over the hood of the car, but so much easier to pack and less likely to mess up my car). Please post your results.
Gravity Grand Touring, 21/22" wheels
