- Nov 9, 2025
- Model X, XC90, S4, LS460
- Air DE Number
- 1
- Gravity DE Number
- 160
- 34DTL9L0
One of the great things about the Gravity’s built-in navigation is the accuracy of the predicted SOC (state of charge) on arrival - usually within a percent. This assumes conditions don’t change much, such as driving style, weather, temperature, etc.
One of the mysteries is the efficiency meter. Is the dynamic range shown accurate? Is the efficiency (mi/kWh) useful? To answer this question, take a look at these graphs and data:
Dynamic range of 137 + 19.4 distance traveled = 156.4. This is the green line hitting 0% SOC. The slope of the green line is the efficiency (2.63 mi/kWh).
What is the white line? It’s a snapshot of the green line (efficiency meter) right after you finished charging, where estimated and actual are identical. As you drive, the green line moves as battery charge level and efficiency (meter) changes. The white line stays fixed until your next charging session.
Is 137 miles (dynamic range) really the distance you can travel? Only on a flat road. This is where navigation comes in.
Notice the green and white lines are not straight. Lucid is starting with the dynamic range and efficiency meter, then adjusting SOC based on the route, taking into account elevation changes. The graph is Lucid’s built-in navigation predicting SOC along the route (white line) vs actual SOC as you drive (green line).
The navigation SOC on arrival is directly related to the dynamic range meter. If conditions change, such as encountering rain, faster/slower highway speeds, wind, temperature, etc., your dynamic range will change and be reflected in the SOC on arrival number. You can look at the graphs to see how your actual driving compares to the original prediction at the start of the route.
Lucid has done a great job on this. There is nothing like this graph on Tesla, with Lucid’s arrival SOC being much more accurate. I could never trust Tesla’s arrival SOC.
