Easy Entry
DLE
Lucid Air
I have a 2023 Lucid Air. The Easy Entry/Exit feature is activated and I have to buckle the seatbelt for it to start moving. It takes several/many seconds before it reaches my saved seat position. The owner's manual tells me where to turn the feature off (Doors & Seats >Easy Entry & Exit) but it is not there on the Pilot Panel. Help!
I believe that tapping the brake after all doors are closed works as well. Go to settings (gear icon) > Doors & Seats > Easy Entry to disable / enaable.
I'm rather small so reaching the brake takes a while so I have to put on the seatbelt to get it going. As I said, the Easy Entry is not listed on my screen. Is it because it is a 2023?
I'd be very surprised if the '23 MY didn't allow you to turn it off. Can you post a pic of the menu where it's missing?
I just checked mine, it's the last option in the Doors & Seats menu:
Just to help guide this new owner, note that as the image shows, there’s one missing step in DS9’s menu navigation instructions….
Settings (gear icon) > VEHICLE > Doors & Seats > Easy Entry
The easy entry menu setting is only available on the owners profile.
It globally affects all other profiles, so that everybody gets or everybody doesn’t get it.
Screenshot of my Pilot Panel
Your profile "Diane" probably is not the primary profile.
If you go to the primary profile you should be able to toggle the Easy Entry setting.
Them go back to the "Diane" profile and it should now work the way you want.
Brilliant!!! That was it. Thank you so much.
TIL... I only have one profile in my vehicle so this would have left me scratching my head. Good call @st50maint 👍
