From
@SaratogaLefty :
Lucid Dream Delivery Checklist
- Homelink Instructions
- Alexa voice command training needed?
- Navigation Set Up - Set Upper Nav Screen to 3D and lower to 2D
- Check Surround View for Parking Assistance
- Check Both Front Seats Heat and Cool Ventilation
- Check Seatbelt Retraction and Height Adjustment - All Seats
- Check Air Vents Adjustability
- Check Windshield Wipers - Proper Seating and Operation
- Trunk rubber gaskets
- Trunk alignment and clearance at bottom – Sharp Edges? Marks?
- Rear door seals
- Open/Close “Frunk” multiple times to ensure smooth operation using Fob and from inside the car
- Adjust the Side Bolsters all the way in and all the way out to see if any “popping” noise
- Massage Seats – Try the Deep Setting on Level 1, 2, and 3 to see if any difference?
- Setting up Profiles for Key Fob and Mobile Key
- Mobile Key setup on Lucid App
- Facial Recognition Profile Setup
- Key Card vs Key Fob vs Mobile App (Iphone) for Locking/Unlocking (all on person)
- Make sure all door handles respond to pushing/pulling
- Approaching with paired mobile key causes vehicle to unlock (various angles).
- Unlock vehicle with non-paired key and make sure it recognizes main driver's face
- Window shades operation fully functional
- Instructions for Hard and Soft Resets
- Reboot sequences: power the car down and back up to check screen loading because some cars are in service for a couple days to replace a faulty module
- License Plate attachment – proper screws and tightness
- PPF and Ceramic Coating – What does Detail Shop need -Key fob or Key card?
- Setting Up Lucid App and proper charging procedure with EA (EA Account Setup)
- Siri Shortcuts on Lucid App
- Bluetooth operation for Apple Music and books on tape (not “Audible” app)
- Quality of Glass and Carpets? Scratches on paint or glass?
- How to Remove and Replace Aero Covers on Wheels?
Full Test Drive with Rep before leaving Center – Use Alexa And Navigation To Find Nearby EA Charging Station and “Top Off” – Any unusual fan squeal noise?
- Order Lucid Home Charger Unit
- Owner’s Manual Hard Copy?
- When will Apple CarPlay be available?
