Charging stops suddenly after a few minutes at Tesla superchargers (V3) with known-working lectron adapter
talzer
Air Grand Touring
Despite the slow charge rate at Superchargers on the Air, sometimes on road trips they still make the most sense (e.g., if closer to a restraunt you like). But 3 of the 4 times I have tried to use them, they have suddenly cut off in the first few minutes of charging (after kW ramp; Lucid shows "charging stopped"). I use the standard Lectron adapter (non-Lucid branded), and I used it many times without fail on my old e-tron GT. This is across two different locations, and has occured both before and after I set up plug & charge.
Has anyone else had any issues like this, or might know where to start digging? I'm at loss as to whether it's even a problem with the car or with Tesla.
I have had the same thing happen at Tesla chargers with my Gravity and I have concluded that it was the charger. I have not charged my Air at Tesla chargers so not exactly the same as what you are doing. If you don't see the problem at other networks, it is likely the Tesla charger that you were using.
