- Jan 3, 2022
- Santa Clara County, CA
- Air GT, XC40 P8 EV
- 3OKY7YGA
Right, I was thinking that the charger would be on and ready to charge for 23 hours of the day, all day except for 7am-8am. Having the Air set to begin charging at midnight should then work any time you plug the Air in, except between 7am and 8am.The issue I've run into is that the lucid dies not recognize when the charger wakes up without first recognizing it is attached to a live charging cable. If I plug in and don't disable supply side scheduling the lucid eventually forgets that it was plugged in and won't be triggered by the chargepoint turning on. If anyone has a chargepoint and had been successful with other behavior I'm all ears. It seems that 1) this is an issue with lucid software and hardware that isn't simple to fix 2) I wouldn't know if I needed to change my behavior given update release notes aren't very detailed
