Battery RANGE after switching from 21 to 19 wheels
Arun Padala
Dallas TX
Lucid GT; Merc E, GLC,
Hi I have a Air GT 2022,
Finally my 21 wheels life span is over after 29,000 miles.
I recently switched to 19 inch wheels, these were mounted at the Discount Tire store
When I charge the Battery to 100 % the RANGE shows 454 miles only ??
I was expecting 519 miles of battery range when you charge your car 100% with the 19s .
Please see attached pic
Did you reset your wheel size in the settings. The 2022 GT on 19" wheels was only 510 miles.
The miles of range is for EPA drivers and Peter Rawlinson when he's showing off.
If your efficiency is below 4.0 kWh / mile your range is going to drop accordingly.
Use % battery instead. and calculate YOUR range based on your trip kWh / mile. Do not rely on the displayed range.
Also, don't charge your car to 100% and discharge it to 0%. Only professional reviewers are this dumb.
Thanks I was able to fix the battery range by resetting the wheel size
Great. You still may get a bit less because of the age of the battery, but certainly WAY better than you were on the other wheels!
