Battery drain 5% to 6% overnight
sri
Lucid Air GT
M0K0C6AL
I have my 2022 Lucid from last 15months. Since last charge, overnight i have lost 5% to 6% twice. All my keys are far away from car and i am sure they are not waking up the car. I have one phone with mobile key and i have bluetooth turned off. Car is parked inside garage. I have noticed that car cabin temperature showing 87F both the times when the battery drain occurred.
Anyone having similar issues with there car? Tried to reach customer support and all they are saying was keep keys away, it is normal…. I am fine if it is normal, my question is why all of sudden it happened twice in a week after 15months of ownership 😞
Was car outside? In a garage? What was the temp outside of the car?
Its parked in garage and temps in the night are between 70 and 75.
Weird. Maybe restart the software and see if it keeps happening.
I kind of doing that ones or twice in a week already for one or other issues. I am worried about why the cabin temp is at 87F when this happens. May be the drain was due to cooling the battery but why the battery is hot when it is parked inside garage and car is not in use at all.
Is it anywhere near 87 degrees where you are parked, and are you hearing any kind of sound from either inside or outside the car? Just wondering if a faulty temperature sensor is causing the car to moderate the battery temperature. (I assume you've verified that none of the new remote climate management functions have been inadvertently activated, like a rear seat heater.)
NEW EDIT: Just saw your above post @sri. We were typing at the same time.
Have you checked that you don't have 'keep' set in climate?
No. I verify the car is locked and turned off every night before going to sleep 😃. Being extra cautious to make sure Car is not turned on for fire safety.
charging at EA today observed speed no more than 200kwh even with 3% SOC and 45min pre conditioning ☹️
Is the car connected to your home network? If so, you could kind of see how often its turning itself on to the point its connecting to a music service. If you keep on seeing meaningful-ish data consumed ever 30 minutes you would know how often its turning itself on. Also, if the keys are truly that close all the time to the point where its unlocking itself all the time, the battery would die rather quick. I was doing this when I first got the car and the first bat only lasted maybe 3 months. This is what my car pulls a week and how often. If it helps.
My router has no such option :(
Just how does one get this information?
Do you mean get a log for a device on your network? Depends on the device. Even home grade equipment has some level of option to log traffic for a device, but normally not for a long period and it would log everything, thus it might be hard for you to read or find what you are looking for. Send me the model and I can look and see if I can find a way that would not be involved. IF you provide the model, do not send a picture and only provide the model.
