Bass rattle
Futurevet93
Lucid Air Touring
Hello, I know this issue has been presented a few times, but I think I may be experiencing a new issue with my significant bass rattle during bass heavy music. Since getting my car at the beginning of January (2025 Lucid Air Touring), I’ve noticed a horrid bass rattle whenever the music is at a higher volume. In the attached video you’ll see an example of the unusual sound the bass makes whenever the music is at higher levels. Now this isn’t generally how I listen to music or the type of music I regularly listen to, but I wanted to show an extreme example of the rattle that occurs with a very bass heavy song. This rattle sound usually occurs any time the music is set to over 50%. This occurs whether the bass is at 0 or +5 on the equalizer setting. No matter how much I’ve played with the settings, it never fails to rattle above a certain volume. Now I’ve noticed it’s more prominent when using Apple play music, and I think this is in part to how the Apple Music causes the volume to play louder, but it’s also occurred outside of Apple Music. Now one could argue that music listening shouldnt be that loud, but my counter argument would be this- for a vehicle at this price point, no matter the volume, type of music, or setting, it should still function appropriately, and this shouldn’t occur. For reference, what you’re seeing in the video is the back liner pulled down to show the rear bass speaker in operation. Please let me know if this is something anyone else has seen or experienced, because it’s driving me crazy. I had the vehicle checked by lucid, and they chalked it up to a software issue, but I’m not confident with that answer. A software issue shouldn’t cause the bass to make this sound right? I already tried putting spacers between the rear deck and the glass, as that has been suggested before, but the issue still occurs. I think it may be an issue with the speaker itself? The vehicle is equipped with SS not the pro.
Despite this unfortunate issue, I still thoroughly enjoy my lucid and don’t regret purchasing this vehicle. Thanks in advance!
Here is the video that I uploaded to YouTube in case the link didn’t work. I believe YouTube is listed as one of the accepted methods to upload a video.
I am on my 3rd subwoofer (regular SS) after the last two were blown and I don't even listen to music that loudly.
Thank you for sharing. We have a software fix for this coming soon.
Lucid also has a "hardware" fix for this as well. If your vehicle didn't have it placed before you took delivery, there is an additional metal-back adhesive tape any service agent can apply inside the passenger side behind the floor covering (sort of against the wheel well). When I had my snow tires placed, the service attendant popped off the panel on the passenger side below the glove box and saw my Lucid already had the tape applied. He said folks were getting bass rattle from a faulty price of tape that was allowing a rattle in that compartment.
I’m having the same issue. I got my car on 3-27-25 and it rattles at about 35-40%. Mine is the basic SS as well. Did your problem get resolved and how if so? Thanks
I have the same weak bass and rattle. I'm about ready to go to aftermarket equipment which I havent done in many years. Seems like an easy fix with aftermarket equipment but shouldnt be needed on a $100k car.
Do you have Surreal Sound or Surreal Sound Pro?
Surreal Sound.
Surreal Sound Pro is vastly superior. You might have to go aftermarket depending on your vehicle age/year. My surreal sound pro leaves nothing to be desired. It was a fantastic sound system even before the update but after the update, it is superb.
glad you like it. I have already concluded aftermarket is the only way to improve the low end power. My comments stands. $100k car should have a better stereo. I’m not into the fancy multichannel surround just give me good stereo. Mine is brand new and I wouldn’t expect to need aftermarket to sound decent mid to high range is crystal clear but low end is non existent. Below 50hz there’s nothing. It sounds fine until you crank it up when you expect some power it’s not there.
I think surreal sound was kinda sold with that in mind, did you not test drive the vehicle? This seems like something that would have made itself apparent if you had.
To be clear, a rattle is still not expected and you may get a little bit better lows if that's fixed.
Of course I test drove it, with both. Neither has real low end power. They don’t use a proper subwoofer. It’s clipped at 40hz. This is really meaningless discussing. You’re happy, I’m not. You trying to convince me that I screwed up and that’s why my stereo sucks isn’t the least bit helpful.
