An eye shape warning indicator
xwave
Supporting Member
CA
AT, Model 3, Y, CT, VF8
A3D8ZHE3
Yesterday, an eye-shape warning indicator popped out without any warning messages.
I couldn't find this indicator in the owner's manual and don't see anything wrong with my AT.
Does anyone know what the indicator means?
Do you wear glasses or sunglasses ? If so, then I have had that warning as camera can’t monitor my eyes. Another reason is that your steering wheel might be blocking it. Try lowering a bit and see if it goes away.
You can add a second appearance with glasses.
Reviving a dormant thread. So, exactly where is this camera located, that my steering wheel is blocking?
It’s right behind the steering column. It’s the black plastic lip that hangs down about an 1”. Yours is clearly blocked by the column.
Hope they fixed that on Gravity.
The answer is it's in a very stupid place which is why mine's turned off
Yep ... I quickly turned mine off as just about any glance away from the road (i.e. mirrors, navigation) triggered a warning. I haven't reenabled to see if Lucid adjusted it's sensitivity.
Mine's turned off because my preferred position of the steering wheel blocks it and I got sick of the warning. Why would they put it somewhere that it could possibly be blocked (and therefore useless) by a slightly taller than average driver's steering wheel position? I'm far from the tallest potential customer at 6'2"
Well it wasn't in the same location on the prototype that was at the LA launch so either it hadn't made it in yet, its removed or hiding in another spot. In all honesty, until Lucid does something with DDPro it's kind of useless especially given how aggressive it is. If you weren't required to touch the wheel with Highway Assist then I get why it needs to be aggressive but to be that aggressive along with touching the wheel? c'mon! leave me alone! 😂
