Air DDP 'Eyes-On' Monitoring...
Buffalo Bob
Arizona & Washington
Pure AWD 19"/ Lexus SC
Unlike 'Adaptive Cruise' with no self-driving activated, DDP's 'Drive Assist' mode will tell you to 'Pay Attention' if the dash camera senses that you are looking away. This is true whether you are in 'Hands On' mode or 'Hands Free' mode. It would make sense to me for the 'Pay Attention' bar to be set just about equally high for either mode, but it seems like that is not the case. When I have Drive Assist set to 'Hands On' mode, I only get prompts when I would expect to, such as if I look away to change music. Otherwise, the car merrily drives itself along. However, if I toggle to 'Hands Free' mode, I get constant/incessant 'Pay Attention' and 'Take Control' notices until I give up and toggle it back off.
I used to think that I had my seat and/or steering wheel positioned improperly, but since it's the same camera used in both situations, that should not be the problem. Neither should DDP need to be recalibrated if everything works just fine in 'Hands On' mode. Nor, at least in my mind, is there any sound reason why the 'Pay Attention' bar should be set so much higher in 'Hands Free' mode.... or at least not so dramatically different that it goes from practically no notices to constant notices.
I'm wondering... Have many of you noticed whether the Drive Assist mode you are in greatly increases or decreases your eye-monitoring sensitivity?
I rarely use hands-free because my preferred steering wheel position blocks the camera. So HFDA will not activate in that position. However, on occasion, in traffic, I will lower the wheel and use HFDA. But, in those situations, I just put on my shades and look straight ahead most of the time. But, next time, I will see if it seems more sensitive with HFDA.
My point is, if the camera is blocked, you can't use HFDA, but you won't keep getting "pay attention" reminders. Just the occasional "keep your hands on the wheel..." messages. Kind of a catch-22 for your situation though.
I have noticed the exact same issue did this resolve for you.
I discussed this with a couple Lucid employees last Saturday at a Seattle Sales/Service Center get-together. I was told that the 'Pay Attention' bar is indeed set higher for Hands-Free mode vs. Hands-On mode, and the logic is that there is a bit more of a reaction delay when one's hands are off the wheel. More importantly for me, I found out that I have been positioning myself too low for the 'eyes' monitor. In the right lighting, you can see your reflection in the dark piece of plastic covering the monitoring camera, and I have been positioning my seat and wheel such that I could see my face in that reflection. I was told that the camera behind that plastic piece is angled up such that you should instead position your reflection around the top button of your shirt. I tried that on my (admittedly short) Hands-Free drive home, and it seemed to work. (It also gave me better visiblility of both the DDP mode indicator and the turn signal cameras, but at the expense of having to look over the top of the steering wheel more than I'm used to. An equitable trade, IMO.) I plan to do a more extensive test soon, and will report back.
I can confirm it's very sensitive to hands on as well. It pops up a reminder every 15-20 seconds if it can't sense any torque on the wheel
Where exactly is the eyes monitor ?
Maybe I just need to adjust my seat for hands free use.
