120V outlets wattage limit
gmoney90
Gravity GT
Apology if this was discussed previously…
I read somewhere that the Gravity 120V outlets runs at 15amps and with a max wattage of 1800.
Is it 1800W per outlet or is it total combining the one in the trunk and the one in the frunk?
Eg if I plug in two appliances that needs 1000W each, would that work?
Thanks
[…] Is it 1800W per outlet or is it total combining the one in the trunk and the one in the frunk?
Eg if I plug in two appliances that needs 1000W each, would that work? […]
Yes, plugging in two 1 kW appliances into two different outlets will work. All three power outlets can output 1.8 kW (15 A) simultaneously.
