Update regarding Phone as a Key availability for Gravity owners
I am going to disagree with you here. The Fob does doe UWB, look at the RF information in the manual.
The fob may be transmitting UWB, but I’m not sure the car is receiving it. Not yet, anyway.
It certainly doesn’t behave like it does.
It’s also possible Lucid isn’t taking full advantage of that UWB signal. UWB is precise. But they could just be using it as a “okay, we’re at least X feet from the car.” As opposed to “The driver is now exactly 10 feet from the car on the driver’s side front, approaching at 2 mph.”
When I worked on a project with UWB chips, I was able to get to the millimeter accuracy, in three dimensions.
I don’t know whether Lucid is planning on using UWB in their own implementation, or if they are simply going to rely on Apple Car Key / Android key, which they would get by simply adopting those APIs.
Honestly, I hope it’s the latter. Proven solution that literally no one complains about. Ask any recent BMW owner.
Same, and my understanding is they’ll be relying on Apple Digital Key (and the Android equivalent).
when i bought my visitq it did not have mobile key in August 2025... Last month we recieved an OTA update and now mobile key was enabled through apple digital key (apple wallet). Works great.
but it hasn't gone to zero
Definitely not zero. Just yesterday, I was standing literally next to the driver's door and I had to press the lock button maybe 20 or 30 times for the doors to lock. It doesn't happen often, but it still happens.
I'd never had any problem like that with ANY car in the last maybe 30 years.
does it lock when you walk away with the key in your pocket?
I've disabled that, as I don't trust it whatsoever.
It doesn't hurt to keep It enabled. You can still manually lock the car and it'll be there to hopefully catch it if you forget.
It would all be so much better if Lucid had included walkaway lock chirp confirmation like most premium brands already have. Still can't believe they left that one out. So simple and easy to program in.
Even more head-scratching that they didn't prioritize that on any of this year's software updates given the widespread fob issues early in the year. It doesn't fix the fob issues, but it makes them easier to live with. I still find myself craning my neck every time I walk away from this car just to make sure it locks because we can't trust the fob.
Only thing premium about a Lucid is the seats and speed!
Truly the Maserati of electric cars. 🤣
Oh wow, I would hate that.
I want an option to remove the triple tone when I open the frunk or rear of Gravity. I don’t need my car making more noises. I can see the handles and mirrors retract. That’s good enough for me.
To each his own.
Also, my Air and Gravity were both 100% reliable as far as locking when I walk away. The Air would lock when I hadn’t walked away occasionally. But it never stayed open. Unless me or my wife accidentally left our phones or fobs in the car. Which is expected.
I walk away backwards when I exit the car so I can see if it locks and the mirrors fold 😂
My neighbor's car honks on lock, often when he arrives home at 2am. Sometimes I yell "UNLOCKING NOW!" when I leave home at 6am, just to make sure he's up to date.
I will admit to checking my watch app once in a while to make sure the Gravity is locked though.
To each his own.
Ideally it would be a configurable option. Not everyone wants it, which is fine. Can just turn it on or off as a personal preference.
I hate cars that use the horn for lock confirmation. Way to loud and harsh. But a gentler chip is fantastic (like our Porsche Macan EV has).
Even better is offering a Home GPS location exclusion option, so it doesn't chirp in your garage when at home where it's not necessary. But that's a luxury. A gentle chirp really isn't obnoxious like a horn is, even closed in my garage.
Yeah, I do that some too, but seems if I try that, that's usually the time it takes longer to lock and I have to turn back around to keep from walking into someone's car. 🥴
...then the Gravity locks in that 1/2 second as I turn, so I miss it. 😶
I park in casino parking garages a lot so I often can't see the mirrors. There I'm looking for the (quick) tail light animation. Blink and you'll miss it though.
Sometimes I find myself pulling out my phone after I get inside just to double-check lock status because I don't fully trust it. Should have a much higher degree of confidence than that, but alas...
Meanwhile the fob and lock chirp is dead solid perfect on our Porsche Macan EV. Night and day between the 2 cars.
My solution for confirming door lock status during walkaway as someone who likes positive confirmation:
Home Assistant: Lucid Integration -> Add Gravity Door Lock as HomeKit accessory -> native iOS Home app notifications whenever doors are locked/unlocked - extends to Apple Watch as well
Basically, I get pinged on my wrist shortly after I walk away to confirm that the doors have been locked without having to futz with my phone or the Lucid app.
Also enables other conveniences and possibilities:
  • say "Hey/Siri, lock/unlock the Lucid" wherever Siri is available (also "Hey/Siri, open/close the frunk/trunk" if you add those)
  • elegantly expose door lock status/control in iOS control center
  • HA critical/notification to phone, e.g. if unlocked for a defined period of time away from home zone
For the past month, my Gravity will fail to lock 2 or 3 times a week. I’ll get an app notification that the car is still unlocked. Or sometimes I won’t which is worse. So I do now check as I walk away. Really hope PAAK can fix this.
