Aftermarket Wheels for Gravity
I got these and so far, great
They are from Element Wheels in California. When you search for Lucid Gravity, will find choices depending on your size and only compatible no trouble fit will show up to pick your color or style choice. The waiting time is about 2-3 months . The wheel weight is only 14 pounds per piece compared to 35 pound for the OEM version. Since I removed aero winds on the original version, have not noticed any under performance in Kw/mile ( around 2.88 to 2.93 ) combined. ( Orlando, Florida). Those are 20-21 inches wheels.
Did you actually weigh the wheels?
14lb is carbon fiber territory
yes, I did weight the wheel alone before tire installation. 14 pounds front (20 inches) and 14.5 pounds rear ( 21 inches) . that is a fact.
Happen to snap any photos of that?
For 5k I wouldn’t mind a set of these magical wheels. Google Ai seems to think some creative and obscenely expensive things would need to happen to make this work.
And claiming 3000lb capacity…even across all 4 wheels vs just 1…that weight does not exist with 6061-T6 aluminum.
Something doesn’t math. As I said if true I would jump on line and order a set.
If you have more data that would be great.
Just weighted out of curiosity , Not my field. Sorry I can't be of further help. Best wishes and research. ;)
  • Like
Reactions: 037
You are wrong.
Here is a screenshot from the company. Upper 20’s to low 30’s in weight in lbs. Not 14lbs.
@037
You are wrong.
@037
Yea…didn’t take a rocket scientist to spot the lb vs kg markings on the scale…
Guess we all can continue dreaming about 14lb wheels…
If it's too good to be true, it probably is. ;)
Now that we got into this whole weight game I am wondering if my latest 22x11” wheel with a stated 1300KG is just a random number…my Forzaaa Gravity Aether replica at 1100KG was 36lb. And also $1000 more…
Wonder if I am going to find out the difference the hard way…or not.
My last Forgestar wheel was 32lb with 2200LB capacity and flow formed at 22x10 so I think it is within the realm of possibility, but how do you know for sure when China sourced things tend to get creative…they point blank asked me if I wanted the brand name laser etched on it..,I declined and then asked if the weight rating was also imaginary…so I did try…
eBay seller has a 100% rating across over 100 reviews…but do we ever know for sure…
I guess I keep both sets and see which I break first.
