Orbit for Lucid: a Garmin watch app for your Lucid (early alpha, DIY install)
doubletwist
Lucid Air Touring
KFO3YAHA
I got tired of pulling out my phone to check the charge or unlock the car, so I've started builing a Garmin watch app for the Lucid. It's called Orbit for Lucid, it's free and open source, and I'm sharing it in case other Garmin owners want it. It's an early alpha that I've only run on my own setup, and installing it is a do-it-yourself job (see Shortcomings).
How it works: a Garmin watch can't talk to Lucid by itself, so there's a small Android companion app. The watch talks over Bluetooth (via Garmin Connect) to the phone app, and the phone app talks to Lucid's cloud the same way Lucid's own app does. There's no Orbit server and no account with me. You log in once in the phone app, and only a refresh token is kept, encrypted on the phone. The watch never holds credentials.
What works today (on my Venu 3):
  • Main screen: charge as a ring and big number, cabin and outside temperature (85°/87°), padlock, plug or charging bolt, climate-on icon, and how old the car's data is.
  • Glance: charge and lock state in the watch carousel, without opening the app.
  • Lock, unlock, climate on/off at a temperature you pick (in the watch's °F or °C), and refresh. Unlock and climate ask for a confirm tap. Lock doesn't.
  • Wakes a sleeping car before sending a command.
  • Stays current: every 5 minutes, while the watch is connected, the phone fetches status and sends it to the watch, even with the app closed. It never wakes the car, and a switch in the phone app turns it off.
On the roadmap (tracked as GitHub issues, roughly in this order):
  • A read-only details screen: tire pressure, windows, battery health, min/max cell temperature.
  • Frunk and trunk open/close (with a confirm tap), on a second page of actions.
  • Battery preconditioning, seat and steering wheel heat, max defrost and max A/C.
  • AC charging current limit.
  • Later, if there's interest: other Garmin models, multi-vehicle accounts, and a watch face.
Shortcomings, honestly:
  • Unofficial. It uses Lucid's undocumented API, which can change or stop working at any time. It isn't affiliated with Lucid or Garmin, and Lucid's connectivity terms are strict about this kind of thing, so use it on your own account at your own risk. The 5 minute status check also shows up as extra requests from your account (the switch turns it off).
  • Narrow support: tested only with a Pixel phone, a Venu 3, and one US Lucid. Other Garmin models compile but are untested. One vehicle only. Android only, no iPhone.
  • No download. You build both apps yourself (Android Studio plus Garmin's free Connect IQ SDK) and sideload them. The INSTALL.md walks through it, but it isn't easy. I'd rather you could read the code than trust a binary that handles your Lucid login.
  • Slow and sometimes laggy. Unlock from a sleeping car took about 13 seconds in my test, but Lucid's cloud varies a lot. After a command the app keeps checking for about 105 seconds, then says "no confirmation yet" (it may still have worked).
  • A permanent notification on the phone, because Android needs a small service running for the watch to reach it.
  • Battery impact isn't measured yet. I'm running that test now and will post numbers.
  • Written with a lot of AI help by someone who isn't a professional programmer, and it hasn't had an outside code review. Be sensible about a button that can unlock your car.
Screenshots are attached. Code, README and the full details: https://github.com/doubletwist13/orbit-for-lucid
Testers with other Garmin watches (fenix 7, Venu 3S, Forerunner) or a second Lucid on the account would help most. Bug reports and ideas are welcome here or as GitHub issues.
SPECIAL THANKS:
w00t! Nice work. Thank you for taking the time, same to those involved in creating that api. it is pretty cool.
Orbit for Lucid: update (v0.2.2)
A quick update since the first post (v0.1.0). Orbit is still alpha and still works end to end on just one setup: a Pixel 10 Pro, a Garmin Venu 3 and one Lucid.
What's new
  • A redesigned watch screen. The main screen is a ring that fills with your charge, a big percentage, the cabin and outside temperature, and small icons for locked, plugged in, charging and climate on. Lock, climate and refresh are big tap targets (or the side buttons).
  • Pick the climate temperature. Choose a set point from a list, in whatever units your watch uses, then confirm. It also works while climate is already running.
  • Fresh data without opening the app. Every 5 minutes the phone fetches your car's status and sends it to the watch, so the glance and the main screen are already current when you look. A switch in the phone app turns this off.
  • A connection info screen. A small i button on the watch shows when the car last reported and when the phone last updated the watch. The phone app shows the same times.
  • Fixes. The 5-minute updates didn't actually work in v0.2.0, and that's fixed in v0.2.1. The error messages now fit on round and rectangular screens, and the watch shows its own version number.
  • More watches, simulated only. The fenix 7 and Venu X1 now build and run in Garmin's simulator. They have never run on a real watch, so treat them as tentative. If you want another model added to the manifest let me know and I'll test it on the simulator and add it so it's easier for you to build for.
The catch
  • It uses Lucid's unofficial API, which can change or disappear, and it may not be welcome under Lucid's terms. Your account and your risk.
  • The phone now asks Lucid for status every 5 minutes on its own, from your account. It doesn't wake the car, and you can switch it off.
  • Android only, and Garmin watches only. You build both apps yourself and sideload them; there's no store version.
  • One vehicle only (the first on the account), and battery impact over days isn't measured yet.
  • The code was written with heavy AI help. I'd welcome a real Android or Garmin developer looking it over.
Code, install steps and release notes: https://github.com/doubletwist13/orbit-for-lucid (releases: https://github.com/doubletwist13/orbit-for-lucid/releases)
Feedback welcome, especially from anyone with a different Garmin watch.
Orbit for Lucid v0.3.0 (alpha): frunk, trunk, horn and lights from your Garmin watch
Orbit is an unofficial Garmin Connect IQ app, with an Android companion, for checking and controlling a Lucid from your wrist. v0.3.0 adds more controls and a few visual changes.
New
  • Frunk and trunk. Open or close them from the watch. It asks you to confirm, then waits for the car to report the lid. A gas-strut frunk can only be unlatched, so it goes straight to the confirm for Open.
  • Horn and lights. One short honk (with a confirm tap) and a light flash. Lucid's API doesn't confirm either, so the watch says "Sending..." and means only that the watch sent the request.
  • Paged actions screen. Lock, climate, frunk and trunk are on the first page. Horn and lights are on the second. Swipe or use the up and down buttons to change page.
  • Charge ring colours. The ring turns green, yellow, orange or red by battery level, and dims when the data is stale. Charge state changes color of battery SoC in Glance as well.
  • New icons. Padlock, battery and plug on the glance and main screen. The plug state is always shown.
Also since v0.2.0
  • The 5 minute background updates now work, with connection info on the phone and watch.
  • Layout fixes for small and rectangular screens, and a scrolling list for the climate set point.
  • The phone app is status and settings only. You control the car from the watch.
Before you try it
  • Alpha, and unofficial: it uses Lucid's unofficial API, so it may break or break the rules, and it supports one vehicle.
  • Tested on a Venu 3 and a Pixel 10 Pro with one Lucid Air with powered frunk. A gas-strut frunk and a Gravity are untested.
  • Update the phone app and the watch app together.
  • Nothing is attached to the release. You build both apps and sideload them, following the install guide in the repo.
Release and install guide: https://github.com/doubletwist13/orbit-for-lucid/releases/tag/v0.3.0
Orbit for Lucid v0.4.0 (alpha): a much fresher glance and faster lock/unlock
Plus the phone and watch now show each other's version. Still alpha: it works end to end on one setup (a Pixel 10 Pro, a Garmin Venu 3 and one Lucid, an Air with a powered frunk), and one tester reports it working on an Epix (Gen 2).
What's new in v0.4.0
  • Faster command confirmation (#46). After a lock, unlock or similar, the phone checks the car every 1.5 s for 30 s, then every 5 s, using Lucid's GetVehicleState call, which showed no rate limit in testing. A lock confirms in about 2 s, and a sleeping car wakes in about 2 to 3 s.
  • A fresher glance (#47). The phone reads the car in the background every 60 s while it sleeps, 30 s while it is awake or charging, and every 10 s for 2 minutes after you use the watch. It sends the watch a change at most once a minute (every 10 s in that window), plus a status every 5 minutes. A lock change shows on the glance within about 10 s of using the app.
  • Battery. The watch drained about 0.55 to 0.6% an hour in every run, with or without the faster updates. The Pixel 10 Pro spent 0.217 mAh overnight on Wi-Fi and 33.7 mAh over a 5 hour day that included cellular use, which is about 0.14% of its battery an hour. The note is in docs/research/battery-findings.md.
  • Unknown lock state (#41). If the car reports no lock state the watch shows an amber padlock with a question mark, instead of passing it off as locked or unlocked.
  • Versions on both screens (#39). The phone shows the watch app's version and the watch shows the phone's, and the watch says "Update phone" if the phone does not know a command.
  • Fewer rough edges (#44). An account with no vehicle shows "No car found" instead of an unknown error, a sleep-update car counts as asleep, and error messages on the phone say what to try. A rate-limit answer while a command is being confirmed no longer fails a command the car already accepted.
  • Thinner watch icon lines, and Android CI that runs the unit tests on every pull request.
Release notes: https://github.com/doubletwist13/orbit-for-lucid/releases/tag/v0.4.0
Orbit for Lucid v0.5.0 (alpha): Significant UI updates
A redesigned watch app: a vertical page strip with an information-only main screen, an info page, and one Access page of seven icons. Still alpha: it works end to end on one setup (a Pixel 10 Pro, a Garmin Venu 3 and one Lucid, an Air), and the Venu X1 and fenix 7 have only been looked over in Garmin's simulator.
Update both apps together. A 0.5.0 watch app with an older phone app shows "Update phone" for the new commands.
What's new in v0.5.0
  • Vertical pages (#55). Swipe up or down, or use the up and down buttons, between the version page, the info page, the main screen and the Access page. Swipe right is back, and small dots on the left show where you are. Design note: docs/watch-design.md.
  • A new main screen. Information only, so a stray tap does nothing: the charge ring, the charging power in kW, cabin and outside temperatures, and warning icons for an open frunk, trunk or door, a tire pressure warning and (in red) an unattended occupant. A quick lock mark by the top right button opens the lock or unlock choice.
  • Info page (#11, partly). Climate state, temperatures, the coolest and warmest battery cell, battery health, odometer and the four tire pressures. Open windows are not shown yet.
  • Access page. Seven icons round the lock: frunk, trunk, close all windows, lights, horn and climate. Climate's second screen now has pet mode. Every send shows a toast, and close windows asks for a confirm tap. The car ignores many commands in gear or while moving.
  • Version and refresh page. When the car and the phone last reported, both app versions, and a tap to refresh.
  • Phone vehicle details. A read-only screen listing what the car reports, with efficiency (since last charge, last 30 mi, all logged) worked out from an odometer and energy log kept on the phone. The charging schedule time now shows in local time. The phone app has no controls, by design.
  • Docs. README rewritten for the new screens with an icon legend and new screenshots; the privacy list now includes the odometer and the energy log; a touchscreen watch is required.
NOTE: I haven't tested the unattended occupant - I'm not 100% sure that works or is supported by all or any of the current models? Also haven't let the air of my tires to test that warning icon yet either. :)
COMING SOON:
- Charging Actions - Another actions page for charging settings, like current limit, charge limit, preconditioning, etc.
- More Colors - a picker to let the user decide what color the app writes in - in case somebody doesn't love an old unix green phosphor screen vibe.
COMING SOON:
0.5 is a nice redesign and its working well, the only button i couldnt get to work was the window roll up, i rolled down the driver side window to test and it never responded ¯\_(ツ)_/¯
Disregard, window roll up does work, (its not consistent, but it works, even with multiple windows down)
Even still that's odd. I'll try to do some more testing. The only time it didn't work for me was when I was in gear.
Then again, I didn't test it super thoroughly. It worked the first few times I tried it (from car asleep or awake) so I committed and called it good. 😎
COMING SOON:
This is pretty cool stuff you're doing here. Unfortunately, I'm not tech savvy enough even to try to install/build the stuff you have done. If it gets to the point where it's simple enough for a simpleton like me, I'd give it a try! Galaxy S23 and vivoactive 5 if that information matters. Very impressive either way though!
I didnt think i was savy enough either, but ChatGPT walked me though it step by step, once you know the steps it took me 10 mins to build the watch and android app. But you will need to update the manifest list for your vivoactive.
I just stumbled unto this thread after your post on DeaneG's app post. Great job for this! Ill try to build and test this weekend (same phone: pixel 10 pro xl....but fenix 8 watch). You can use the simulator for the watch but it's going to be interesting for the watch because the fenix 8 was the first watch with the new code base. I'll post.
Btw, just for my information, the battery % drain, I'm assuming that's the drain when the app is open on the watch, right? I wouldn't think it'd lose 13-14% per day just being on the watch
The battery drain on the watch is the total drain of just using my watch overnight. That includes all my sleep tracking, heart rate, O2, etc.
I haven't yet found a way to get stats on how much the app itself used, unlike on the phone/Android side.
I haven't been able to tell a noticable difference in overall battery drain on the watch vs before I installed the app, though it's admittedly hard to tell with this watch given that it lasts 7-12 days on a charge anyway even with all the sleep and health tracking.
gotcha, makes sense. I was about to say..i lose about 5-7% per day if i'm not doing an activity..the burn rate of that one app seemed disproportionate hehe. that's one of the best benefits of the garmin watches...battery is nutty. i'll report back over the weekend or on monday if i could get it to work and how it worked with my fenix 8
Orbit for Lucid v0.5.1 (alpha): Minor Updates
A small update to 0.5.0. Still alpha: tried end to end only on a Pixel 10 Pro, a Garmin Venu 3 and one Lucid; other watches were checked in Garmin's simulator at most.
Update both apps together. (phone and watch)
What's new in v0.5.1
  • Accent colour (#65). Pick the colour of the icons, text and glance from 11 presets (green by default) with the Colour button at the top of the About page, or by holding the menu button on watches that have one. The charge follows it from 50%, then turns yellow, orange or red as before; warnings are never themed. Kept choices limited to avoid conflicting with the warning colors.
  • Efficiency log per vehicle (#67). The phone keeps one log per car, so efficiency no longer mixes cars or accounts. The old log goes to the first car that reports.
  • Glance (#68). Draws on a transparent background so the system card shows through.
  • More watches (#82). The manifest now lists 30 touchscreen watches, so most people need not edit it. The Fenix 8 47mm and Epix 2 Pro 47mm were run in the simulator; the rest only build.
Known gaps
  • Held-button picker untested except on the Venu 3; the Venu 4, Venu X1 and Vivoactive 6 reach it only from the About page.
  • Mint/Teal and Violet/Purple look alike on small-palette watches.
  • Forerunner memory limits follow the Venu 3 profile and are unchecked on hardware. The Forerunner 265S ran the accent picker in the simulator.
  • Second-car logging is covered by unit tests only.
Planned for v0.6.0
  • A Charging page on the watch. It shows the charging power and has start and stop, a charge limit, and opening the charge port (#35).
  • Battery preconditioning, on that same Charging page (#13).
  • AC current limit (#14). This one needs research first, so it may slip to a later release.
  • Easier install (#83). Better install documentation and a script that does the build and sideload steps, since installing is the biggest hurdle today.
  • Considering: a vibration and a final toast when a command finishes (#72). This isn't committed.
NOTE: I would like to add proper multi-vehicle support but I don't have any way to test it. If someone with a Garmin watch AND multiple Lucid vehicles would like to assist (by building and testing the phone and watch apps from a git branch), I'll add that more specifically to the roadmap and release it earlier. Just DM me!
so update from a fenix 8 47mm...everything seems to work well! I have the charge state, did a few button tests...the first one took a bit (car was asleep) but once it woke up the car, everything worked as it should!
Great job double twist!
I didn't have any of the stuff installed other than the android sdk..and compiling (I hadn't done so in years) took a while...so full install of tools needed, compiling, installing on phone and watch took a bit less than an hour, so not too bad for a first run. I assume the updates won't be that bad going forward :)
when I have some free time, i may contribute to the code or suggest some things if I can figure things out, but for now, double twist is the man (or woman)! nice feature for our garmins :)
Orbit for Lucid v0.6.0 (alpha): Charging Controls
A 0.6.0 watch app with an older phone app shows "Update phone" for the new commands.
What's new in v0.6.0
  • A Charging page (#35, #13, #14).A fifth page, below Actions, with the bolt in the middle and four icons round it. Every command asks for a confirm tap first.
    • Bolt: start or stop charging. A start is refused at once with "No cable" or "At limit" instead of waiting to time out.
    • Charge port: open or close. A close with a cable plugged in is refused at once ("Cable in"), as the car does not close it then.
    • Charge limit: a list from 50 to 100% in 5% steps, with the current limit shown under the icon.
    • Battery preconditioning: on or off, filled in while it runs.
    • AC current limit: a menu of common values (10, 16, 24, 32, 40, 48 and 80 A) and "Other...", a picker over 10 to 80 A. The amps shown are what was set; when the charger is lower, its maximum follows in brackets, so 80A(40A) is 80 A set on a 40 A charger, which draws 40 A.
  • A result toast and a buzz for every command (#72). When a command ends, a toast names the action and how it ended ("Unlock: done", "Frunk close: not confirmed", "Charge start: no cable"), with one buzz for done and two for failed (unless the watch's vibration is off). Horn and lights say "sent", as nothing can confirm them. On the one car tried, an unlock showed "done" in 2 to 3 seconds from an awake car and 6 to 8 seconds from a sleeping one.
  • Car giving power out (V2X). The glance, the main screen and the Charging page show an outlined bolt with a small red arrow, and the page offers no start or stop.
  • Faster reads (every 30 s) while the battery is preconditioning or the charge port is open with no cable, even if the car reports asleep.
  • A command log for debugging: adb logcat -s OrbitCmd shows each watch command, how it ended and how long it took. It holds nothing about your account or car.
  • Docs. The README's "Using the watch app" is organized by page (About, Info, Main, Actions, Charging) with a new Charging screenshot and icon legend. PLAN.md no longer holds a roadmap: the GitHub milestones are the plan.
Known gaps
  • All of it was tried on one Air. The charge port has not been tried on a Gravity, whose door is believed to be manual, and a car that reports no state for the port shows the flap closed and says "sent" (not tried: the Air reports one).
  • The minutes left for preconditioning have never been seen: the car sent a too-large placeholder, which the phone hides, so the label may stay empty.
  • What a car reports while giving power out (V2X) has not been seen, so the page shows no kW then.
  • A long result toast on the round bezel ("Climate off: car didn't wake", 28 characters) has not been seen; the longest tried, "Port close: not confirmed", fit.
  • The AC limit is capped by the charger, and nothing says so except the bracket in the label.
  • Forerunner and other memory-limited watches were only built, not run on hardware.
Planned for v0.7.0
  • Charge finish time: shown on the watch while charging.
  • Charge limit on the ring: a mark on the main screen's charge ring, so you can see how far it has to go.
  • Charging schedule: show the next scheduled start, and switch the schedule on or off from the watch. Editing the times stays in Lucid's app. The first step is checking how the car reports it.
  • Last known state on the choice screens: the lock, frunk and trunk choices will show the car's last known state and how old it is.
  • Windows: which windows are open, on the watch. The tire pressures, battery health and cell temperatures are already on the Info page.
  • A needs-attention indicator on Main: for things like a low keyfob battery.
  • Software updates: whether one is available, and its progress.
  • Phone: the car's status in the foreground notification, and a clean-up of the "Vehicle details" screen so its values stop repeating the field names.
Tentative
  • Multi-vehicle support (pick the car) is in v0.7.0 only if someone with more than one vehicle can test a branch. If nobody can, it moves out. If you have two Lucids on one account and could try it, please say so.
ALSO: I'm open to suggestions if there's any particular controls or info I don't already plan on adding. I've pretty much added most of the things I care about (or are already planned on the milestone) so let me know if there's anything you want that isn't already in the milestones or any of the 'later' tagged issues you think should be moved up!
New watch 'Charging' page screenshot attached showing the:
- Charging start/stop (center)
- Charge port Door Open/Close (top)
- Battery Charge Limit Percent (left)
- AC Charge Current Limit Set (right)
- Preconditioning start/stop (bottom)
Orbit for Lucid v0.7.0 (alpha): Status at a glance
An older phone app does not send the new finish time or window fields, so the watch simply shows nothing for them.
What's new in v0.7.0
  • Charge finish time (#70). While charging, the main screen shows "by 5:10p" under the kW, with the weekday ("by Thu 8:10p") when it is not today. It is the car's own estimate, rounded to 5 minutes.
  • Charge limit tick (#71). A small tick on the charge ring marks the limit until the charge reaches it.
  • Windows (#11). An amber windows icon on the main screen while any window is open, and a "Windows" row on the Info page.
  • Choice screens show the current state (#38). Lock, climate, frunk and trunk choices show what the car last reported and how old that is.
  • Stale data is flagged, not dimmed. The main screen stays readable and the status line says "Nm old" in amber.
  • Main screen layout. Inside and outside temperature are on one line at the top ("70°/82°").
  • Phone notification shows the car (#73). The watch-link notification reads like "79% 🔒 ⚡7 kW". The lock screen shows the plain text.
  • Phone Details screen (#95). Values no longer repeat the field name ("model air" is now "air").
Known gaps
  • The finish time has been seen on one car and one charge; a car that reports no estimate shows no time.
  • The new layout was checked on the Venu 3 and Venu 3S, and in the simulator for fenix 7, fenix 7S, fenix 8 and Venu X1. Other watches were only built.
  • The windows icon and Info row have only been seen in the simulator, with a test message.
See docs/protocol.md for the new fin and win status fields.
Screenshots showing
- Main screen with charge limit tick, and finish time estimate - with int/ext temps moved up to the top right.
- Main screen showing ALL of the status icons
- Phone notification showing status and charge speed.
