Lucid Air Touring - battery "upgrade"
DreamTour
Bay Area, CA
Air Touring (Dream Rims)
SU5XF4DI
Well I got my Lucid Air Touring (early build) back from the shop for the drive system warning / battery imbalance.
Happy surprise is that while the parts seem to suggest a re-manufactured pack was put in: The API says I now I have a SDI (Samsung) celled pack with 100% health and 93.44 KwH storage. IIRC the LG packs were 88 KwH.
Yay more range! My first build run Touring now has the CCCv2 and a new battery pack. I think I'm only missing the heat pump and motor mount upgrades now.
Is it sad / bad to say I hope my front motor fails so I can get that upgrade too?
Actually, only the single motor Pure has the 88 kWh battery. Yours should be 92 kWh, but I don't think a little extra cushion is unusual.
Thought the 2026 touring gained some range - assumed it was an updated cell for a bit more capacity since the heat pump went in 2025 I think?
How do you check the battery?
Do you know if there's any warranty on your replacement battery?
Same warranty period: I only have 29k miles / 4 years on the car, so warranty will be up at the 8 year limit the rate I'm driving it.
BTW the Samsung Celled battery definitely has a bit more juice than the LG one new originally. Added about 5-6 miles of range fully charged!
My new battery seems like I have a new car. Not only do I have significantly more range and better efficiency with this battery than before the replacement, but I think I have better range and efficiency than when the car was new 3 1/2 years ago. Out of curiosity, how would I know if I got a Samsung battery or what I had previously?
https://testmycode.cc , search for "batteryCellType". I think it wasn't until ~2025 they switched to Samsung cells (SDI), so if your car was older it would've been LG (except for Dream Editions I believe?). I'm also not positive that data updates if they swap your pack though.
Thank you. But I don't know how to interpret this:
battery_cell_type: BATTERY_CELL_TYPE_SDI_50GV2 (4)
Field 17, battery_pack_type: BATTERY_PACK_TYPE_AIR_18 (2)
What does my values imply? It is odd testmycode is reporting unknown for my 2026 Pure battery type. And battery pack type is 16.
Gravities are all reported as UNKNOWN as well. What this means is no one at Lucid has put new values into this system in a couple years now :p
16 sounds right though, I forgot, 18-module is Touring and Pure-AWD. I think Pure-RWD went down to 16.
My efficiency is up too after the change. Like 10-15%. in retrospect, not surprising since they said I had a 15% cell imbalance. My understanding is to balance the cells they basically bleed the energy off of the other cells to match to poorest performing module. So making 15% extra heat...
