Smashed rear windscreen
geosynch
Air Touring, Ioniq 5
OWLPTRZ3
This just happened.
Occured while parked in a parking lot. I didn't notice the damage until I got home. I went back to the parking lot and saw glass near where this part of the car would have been, but no evidence of anything that "hit" the car.
My initial reaction is that this should be a strightforwaard replace since there are no sensors in the rear screen... but after reading a few threads, it seems that the trim around the glass cannot be reused, so, the price just goes up and up and is likely to be $5k. I was going to go out of pocket if it was $3k or less. Hmmm....
Anyone in the South Bay or SF peninsula who has gone through a rear screen replacement recently? I'd like to commiserate.
This just happened.
You didn’t notice all the dead Dinosaurs either?!?! The coming ice age??
Well it was round and I don’t see blood so not someone’s head and probably not a brick. Wrong shape of impact.
And tell me again how long you drove like that before you noticed?
Maybe 10 minutes.
From the driver's seat, the view of the rear window is a bit obscured by the rear sunshade
Have no idea how you couldn’t notice that when you walked up to the car, when you got in, when you looked in the rear view mirror - it isn’t exactly subtle. Looks like someone took a sledgehammer to it.
Passenger side, I approached the car from the driver's side. The car was backed into the spotSo, I did not need to use the rear view mirror getting out of the spot.
I drove 10 minutes home, pulled into my garage nose first. THere was no real need to use the rearview mirror, although i'm sure I glanced out it once or twice.
Sh!t happens.
Yes, it does look like a hammer hit it. I wish our cars had a camera view like Gear Gaurd.
How well can you see it from the driver's seat, even when you're looking?
My first thought was a stray golf ball from a nearby driving range, but the diameter of the crater suggests something larger and heavier. Almost certainly spherical. You can practically see the first point of impact where the lines converge to a spot that's maybe a centimeter across. I assume you weren't parked at a sports complex. I'm intrigued by what could've done that.
Sadly I would guess vandalism from a brainless punk. Sorry this happened to you.
Near a bowling alley, perhaps? I've had a ball come loose once in a while... 🤣
Sorry it happened - but sooo great it doesn't appear to have hit the body!!! THAT would have left a mark... and, a bigger price tag!
Quote is for $3,044 at Lucid San Jose. My insurance will cover. The appointment isn't until Nov 10, and I wish it could be tomorrow, but it is what it is.
To answer a few questions, my car was parked at a local church. Nowhere near anything like "legit stray" golf balls, etc.
This does look like a blow from a hammer, but honestly....? In the middle of that crater is a fairly defined sharp impact point. I wondered if it could have been a bullet. If it was, it did not penetrate the glass and there was no supporting evidence at "the scene of the crime." Something blunt and ~3.4" in diameter like a hammer doesn't even fit the damage's pattern....
I guess I'll never know.
Tesla fanboi?
Diesel truck owner?
Does the church have security camera footage?
Were you parked under an oak tree? Acorns can shatter glass.
I've had a pine cone fall and hit my car. They’re light weight once they've opened up, but fresh out of a tree they're solid like a brick. And they fall from high enough to build up a lot of kinetic energy. These days I try really hard to not park under a tree that could drop one. A pine cone is about the right size for the shatter pattern.
What you park near sequoia’s?
This just happened.
I feel your pain. My car has been at a collision shop for a few days now waiting for the rear glass roof panel to be replaced. Whyizzat? Self inflicted wound. Had a couple bikes on the roof carriers and hit a monstrous dip in the road at highway speeds. One of the bikes bounced enough that the pedal hit the roof.
As you mentioned, the trim panels have to be replaced along with the glass, as they are one time use. And to top that off, since I had all the platinum trim wrapped in a dark graphite (Stealth-esque look) that also has to be redone. Insurance is covering the $4k repair.
Crazy... at a church parking lot no less. Sorry this happened to you.
