Crash
Doug-In-PSCA
Grand Touring
Hello everyone. I just read a post (and numerous responses) from someone who had a terrifying experience with the car instantly accelerating and finally crashed into a wall. Most members made comments that it was most likely driver error - pressing the accelerator instead of the brake. And I know this is usually the accepted result by Lucid and other experts. I had a somewhat similar problem yesterday that ended in a very quick, frightful crash. Fortunately, no one was injured, but a lot of damage to the car and to the building I hit.
I pulled into a parking space to attend a doctor appointment. There was one car parked to my right; my space is a DP (disabled person) space and to its left was an area of about 6-8 feet wide with blue stripes where you are not supposed to park. I realized I was over the left line onto that area, so I slowly and methodically turned the wheel while backing up slowly. I backed completely out of the parking spots and aligned myself to be perfectly centered in the space this time ("overhead" camera view showed that ahead). Note that I always use regen braking, so the car stopped gently after I had backed up. Remember there is no need to touch the brake pedal here. Knowing I was aligned, I pressed the stalk to DRIVE and the car instantly flew like a jet before I could even recall pressing the accelerator at all. There would have been NO effect had I pressed the brake (I was already stopped). And I certainly would NOT have pressed hard on the accelerator, although I don't even recall a thought about it because it happened SO quickly and with such great force. Yes, as someone pointed out, I was terrified and literally froze, grasping the wheel. I flew through the roughly 16 feet of parking space, jumped 2 curbs about a foot apart, crossed another 4 feet or so and crashed HARD into the stanchion that supported arches above (design of the building). I did NOT pull into the parking space, nearly to the curb, and then hit the accelerator instead of the brake (as is so often reported in the news, etc.)
Given that the new 3.0 UX software was recently installed (and I had lots of glitches -- things like the vehicle centering capability (that I always keep off - too aggressive) kept coming back on. Turn it off, back on again... over and over again - parts of the screens dark - having to reboot frequently. I firmly believe this sudden acceleration was caused by the car itself and was NOT driver error. I hit the wood and stucco stanchion VERY hard and don't understand why the air bags did not deploy. I also don't understand why the collision avoidance system did not kick in either, thinking it would have at least slowed the impedance. Does this not work over a certain MPH? It surely works when I back out of a parking space, don't see someone driving by behind me. It slams on the brakes.
Don't know yet if it is totaled. The body shop (certified for Tesla and Lucid) didn't think it was and said a ballpark estimate is probably around $30K of damage! He said that the computer/black box data only provides "graphs" and likely would not show that the accelerator was pressed hard by the driver, or if the car did indeed malfunction. If this is true, nothing can be proven I guess?
The body shop also said to not expect to have my car back until nearly Christmas - that they have SO much trouble getting parts promptly from Lucid.
I'll post any updates as I know them. Thanks everyone.
Sounds like something I did without the crash part. Drive, drive, drive all the time with regency and it’s easy to have a bit of pressure on the pedal with that maneuver. Add in started and it’s so easy to over compensate.
Mine was first interstate entry ramp and suddenly noticed a car coming fast to block the lane. I hit the throttle and suddenly I’m closing in on 100 (this was in Mexico) and it took a moment think and lift off. And immediately lay into the real brakes.
Luckily that was in smooth mode.
Lucid should look into this to determine if this is a driver error or fault of the car. Being proactive from a company speaks volumes. I will say, I had experienced something unusual with my Lucid. Driving through a pothole once, the car felt like it accelerated by itself faster than my cruising speed when I hit a pothole. It was scary to a point where I had to hit the brakes. It was as if the traction control was trying to compensate by accelerating. Anyone else experienced this before??
It doesn't compensate by accelerating, but the traction control / ABS system will fully disable regen for a moment in situations like that which can feel like acceleration. Same as traditional ABS, the goal is to prevent the wheels from locking up by letting them roll freely. It does feel weird though.
Please do keep us updated on this. I was disappointed when that other user kinda disappeared.
I'm curious why you think braking would have had no effect?
View attachment 41780View attachment 41780View attachment 41780View attachment 41781View attachment 41782View attachment 41783
The logs will absolutely show if you pressed the accelerator or not. UX 3.0 has nothing to do with the drive systems; it literally cannot, as it is exclusively an infotainment update on the CCC, which does not have access to the drive controls at all. That is a red herring.
I’m sorry this happened.
I think he meant to imply that had he pressed the brake it wouldn’t have accelerated, but that he felt there was no need to as he was already stopped.
Glad to know you are okay, that's a scary situation. I'm with you, it'd be interesting to learn why the air bag didn't deploy and the crush avoidance didn't engage.
Those pillars are 2x4’s you wouldn’t want the airbag going off when you just run into them it would mess you up. The hit wasn’t that hard impact wise, it was just a lot of area.
This is correct.
Sorry this happened but the vehicle logs will reveal all.
Hopefully we’ll get a report of what the driver/car did. Somehow I wonder if people actually acknowledge what happened or if they will just drop off?
I would think it's possible to overpower any acceleration by stomping on the brakes or left foot braking. But it's not impossible to have acceleration glitches that are too fast to react to...
Isn't the expected process to put one's foot on the brake before selecting forward or reverse? Maybe I just do it out of habit as I always have since I learned to drive...
It's funny... I never actually considered letting the Hold Mode braking play any part in the process of changing drive direction.
1) Car comes to stop with Hold
2) Depress brake pedal anyway
3) Change between Drive and Reverse
I do make an exception for switching to Park; doesn't feel necessary to press the brake for that one. But something about changing the car's direction of travel (especially for a 3-pt turn or similar maneuver) compels me to ensure the car is completely stationary before fiddling with the gear selector.
This and the post just above you were responding to have definitely caught my eye.
I do tend to let the regen braking serve the purpose of the brake pedal in these situations…. It happens every day when I back out of my driveway, then shift into drive once I’m in the road. These couple of reports of unusual acceleration might encourage me to try to go old school just to be safe?
It would surely be helpful if Lucid itself would report on what it found in these two scary situations! I wonder if that is beyond the scope of what @marqie might do for us?
I found myself doing that without thinking about it as well, but a while back I noticed it when I impatiently and absentmindedly shifted before coming to a full stop. There was no gear grinding or anything like that, but I'd swear (though I don't really want to try reproducing) that my next step on the accelerator accelerated me in the wrong direction. I forget the details, but something like I shifted from reverse to drive while still inching backwards, the indicator showed D, but the accelerator accelerated backwards. Any brave souls want to try that move for science? 😬
Anyway, yeah, now I use the brake pedal like a responsible adult.
Personally? Nope. I like those gear faces far too mutch.
Probably totaled, you probably pressed the accelerator by mistake.
