Correct your cameras always stopped at 17mph the deploy screen at 15mph is new.Yup, discussed quite a bit in the other 2.11 threads. I reported this to Lucid, mobile service is coming out on Thurs to take a look at mine. Most likely we'll just have to wait for a software rev.
It's been determined this behavior is tied to vehicle speed - when dropping below 17mph the pilot panel deploys itself. This is also the speed that the parking cameras cut out, so I'm guessing it's a bug tied to some new logic to automatically deploy the pilot panel when cameras are in use.
Make sure to report this behavior to Lucid via support. The more they hear about it the more priority it'll get from the developers.
My loaner does this too, fyi.Correct your cameras always stopped at 17mph the deploy screen at 15mph is new.
It can be a problem if I have something currently occupying that space.
But to be honest I see what they were thinking, I’ve seen this often when the }>><*~<<!€ analyst doesn’t insist on talking with as many different end users as possible. This is NOT a developer problem this is missed requirement during the requirements phase. And even if you’re running as an agile shop you still need end users involved and you need fast turnaround like something every two weeks. You don’t need to deploy to the end users but the stakeholders need to see and sign off every two weeks that what is being developed is what was actually intended
Immediate edit
This and all ev’s are complex and able to readily kill you, some faster than others, but all in literal seconds.
And i hope the intro to sw development isn’t too painfully simple and useless.
Another noteMy loaner does this too, fyi.
Of note: it has always brought the screen down when cameras are on, especially in reverse, for example. Cameras are on only at low speeds, obviously.
My guess is simply that logic needs checking, as it may have lost the “and cameras are on” part of that.
No, but when camera views come up, it is supposed to deploy. That it deploys when camera views don't come up, but below the speed, is indeed the problem.Another note
Deploying doesn’t always show camera views, as I am now recalling
I'll try to confirm this next drive. I really want to know when it's going to deploy and with what screen. AND how to make it not deploy would be handy, assuming you have something occupying the space where the pilot panel wants to go. like maybe an over sized cup of coffee or soda?No, but when camera views come up, it is supposed to deploy. That it deploys when camera views don't come up, but below the speed, is indeed the problem.
