Anyone else encounter a strange tear in seat upholstery?
I've got the same problem. 25000mls
I am having an issue in a similar area on my GT where the passenger’s body parts don’t even cover. I sent it to Service a Couple of months ago and was told it was not a problem.
I had my driver side door replaced for a similar issue after a lot of fighting which you might have to do but hopefully this is a no brainer. The service level may be going down now that they seem to be running out of money and are unable to sell as many cars as they produce.
I have stopped watching them or keeping up with them at this point. I will be watching my seat issue and have that difficult conversation if I see the seat leather deteriorating.
I know I am in the minority here but the quality of the leather used is less than stellar no matter if it was caused by the fact that they had to make do with the best they could get during COVID.
Hi All - 2 weeks into the ownership of the 2023 Air Pure and noticed some deformation happening already on the driver side seat.
I have read about similar issues for driver seat tears on this forum….but this one seems in the very early stages, where the tiny bonded perforation holes are just deforming which will eventually lead to a big tear.
I have only driven the car 5-6 times so far with only 150 miles on the odometer.
I’m extremely careful during getting in/exiting the car due to its low height and having read about the seat issues on this forum, but this seems like poor materials and craftsmanship which should be addressed accordingly.
Have already emailed my Sales/Support advisor at the studio about polaris ranger 1000 accessories and waiting for a response back.
Attaching a couple of pics
I’d probably avoid a universal seat cover unless you know it won’t interfere with the seat controls, airbags, or sensors. Since the seat is already starting to look bumpy after only a year, a fitted protector made specifically for the Lucid would make more sense. It might also be worth checking with Lucid service first, especially if the material or foam is showing premature wear. A good-quality breathable cover that fits tightly should protect the seat without changing the driving position or comfort.
Stumbled on this thread... 11k miles on a 2025 Air GT and found this on the rarelly used back seat. Trying to find a leather repair place to see what they can do about it.
Has anyone here successfully had their Lucid seat cover replaced under warranty? Mine is in its third year with about 30K miles, and I’m wondering if Lucid has covered similar issues for others.
Yes. Several examples in this thread. I just had a second tear replaced on the same drivers seat. The second tear was in a completely different area in the mid to upper back section. The first was on the side bolster like in the OP’s photo.
If it is a stress tear along along line of perforations it should be covered by warranty... Get it done before lease return.. The material is comfortable-- but it is just too soft and fragile for car seat
Given that it's probably one if the few things that would stop me from buying out the car at the end of my lease, I wonder how much it would cost to just buy replacement leather seats.
Had the same issue. Does anyone who's had this repaired know if the replacement is tweaked to fix the issue? It happened within a month of ownership so I'm assuming it'll happen again soon if it's the same part.
As of last year it wasn't. Replaced at 11k miles and was tearing again by 17k miles.
I just had my drivers seat cushion cover replaced again.. I actually think the new material feels a bit more stout than previous PurLuxe.. Might be wishful thinking, but time will tell.
I discovered the rip on the driver seat 6 weeks before my lease turn in. I had the seat replaced by Lucid under warranty 2 days before I turned in my lease.
Hard to believe I’ve found my way back to this thread… I thought I had some good news to share, but then discovered more bad news. I had my driver’s seat re-covered during a field service visit last week. After a week of use, the replacement material does feel a bit tougher— not quite as soft as the original material or the previous replacement. I’m hoping that means it will hold up better. However, while stopped at a light, I glanced over at my passenger seat and noticed the beginning of a new tear at the crease in the side bolster. Very frustrating to see this starting again on the other seat. I already placed a call to Lucid service on this....
Makes me wonder, if I were to buy out my lease, his much it would cost to replace the seats with real leather seats.
I reckon that it might be more involved than simply swapping seats, since I believe the leather versions have thigh extensions and may use different controls or control modules. Meanwhile, the replacement cover installed on my driver’s seat last week does feel firmer and more substantial, even though it looks the same. Time will tell whether it holds up any better.
PurLuxe upholstery seems to be most common material in the Air, including Touring, so recurring tears are obviously a significant issue for Lucid. I wonder whether they’ve finally moved to an improved material, perhaps after using up the original stock of covers.
Just noticed these lines on the side bolsters today. I had a prior tear on a side bolster and more recently on the upper center section. Both replaced under warranty.
I've been waiting (for parts?) to get mine replaced under warranty for nearly 8 months now. First the seat back cracked. Then it tore. Then the seat base cracked and tore. Kind of tired of friends noticing it torn up and valet drivers pointing it out to me.
