Sneak peek at Gravity 3.6.4
Does anyone see anything like this? When Dream Drive/Hands free engaged, there's no street lines and no traffic graphics showing on the screen. It's just your own car with the blank screen. Hands free function still worked fine.
No, it's not AI modified/created. It's real pic.
I owned this Gravity for about six months and never seeing anything like this ever before version 3.6.4
I turned off and turned on Hands Free several time, it's still showing the same for the rest of the drive.
Once I stopped the car and started driving the car about an hour later, the graphic started showing normal again. No reboot is needed.
This tells you how bad the version 3.6.4 is. It broke the most basic graphic that was working all along.
Way to make a big negative deal out of a very minor issue. Every piece of software has issues where an old feature bugs out after a new update. Happens all the time on Microsoft/Apple/Android. Report it to them (Lucid) and keep it moving.
What about being able to raise and lower the car via the app?? This would be useful too.
You can already do this. Well designed too. First, you have to be close to the car so you can see it isn't crushing someone or itself.
Version 3.6.4 is a joke. Why can't Lucid learned from the past that you will test it thoroughly before release. I thought the new CEO said quality & service were his priority
* Key fob does show some improvement over 3.6.3, but several times I still have shaking it and walking up and down to get the door open.
* Hands free certainly shutdown and never came back. At least, with 3.6.3, after it shutting down, it was able to come back a minute or so later. I do have Dream Drive 2Pro.
* While stopping at the red light, traffic is not moving, it certainly popped up "Traffic clear" out of nowhere.
Hmm. Sorry to hear this. That’s Not my experience before or after 3.6.4. Lock and unlock are really just … unremarkable now for me because they work reliably. I agree the Traffic Clear is sensitive but haven’t had it chime without some movement. Had the light turned green and traffic had not yet moved? Or was it still red?
Yes, when I stopped the car at my house, walked away for about an hour, and started driving again, this is when the graphic became normal again.
It takes about 2-3 minutes for the car to fall asleep, provided you walk away with all keys and stay away for those 2-3 minutes. If that solved your issue, it was a temporary issue that shouldn’t recur.
I hope
I hope it won't come back. Thanks
The light still red and no other car is moving. I noticed this coming several times in the past. Not a lot, but it did happen here and there.
I had an incorrect "traffic clear" notification yesterday when the opposing traffic got a green light and started moving, but I still had a red light with two cars stopped ahead of me. I sent a bug report to [email protected] and didn't think anything of it past that.
I've seen the same
In my experience, the detection is on the hyper side of sensitive, so if the car in front of me inches forward, it triggers the notification.
I'm glad to have it but I've been conditioned to ignore most of the chimes because of the high number of false positives.
So is robustness a thing of the past, or only reserved for Air?
