hi,
I happen to drive Lucid Air with American Specs 35K km for the past 3 weeks and here are my findings compare to ME Specs with 20K km mileage
My observations after driving both:
My assumption is that many of these changes are intentional, with the Middle East version being optimized for our hotter climate while the U.S. version is tuned for North American conditions.
Has anyone else driven both U.S. and ME-spec Lucids? I'd be interested to hear if you've noticed the same differences or if there are other changes I may have missed.
also, I need to add that I have NOT checked the manufacturing date to compare apple to apple but my guts the US Spec might be older version like 2021 and ME is 2023
the above was written with help of AI and I shall update it as I come across more observations
| Feature | Middle East (ME) Specs | U.S. Specs |
| Mileage of Vehicle Tested | ~20,000 km | ~35,000 km |
| A/C Performance | Colder and more effective | Not as cold as ME specs |
| A/C Fan Noise | Very quiet. Fan is barely noticeable except in extreme heat or after spirited driving. | Fan runs more aggressively and is noticeably louder. My assumption is that it's optimized for colder climates. |
| Energy Efficiency | Better efficiency | Noticeably worse efficiency. I'll try to post photos of the consumption. My assumption is that it's calibrated for different climate conditions. |
| Front Side Reflectors | Not present / I need to double check | Present in the front headlight housing. |
| Front Accent Light (DRL) | Yellow section at the top is eliminated or not active all the time | Includes the yellow section at the top |
| Indicator & Alert Sounds | Louder and more noticeable | Some alerts (turn indicators, blind-spot monitoring, etc.) sound quieter or have different tones. |
- ME Specs: ~20,000 km
- U.S. Specs: ~35,000 km (driven for the past 3 weeks)
