No, that is a myth. While highly resistant, acoustic glass can absolutely be broken open. Because acoustic glass is simply a type of laminated glass (which uses a soft plastic interlayer), it will crack when struck, but it remains remarkably tough to penetrate compared to standard or tempered glass. [
1,
2,
3,
4,
5]
How Acoustic Glass Handles Impacts
Because acoustic glass is essentially two or more panes of glass glued together with a special acoustic polyvinyl butyral (PVB) resin, it behaves entirely differently than regular glass: [
1]
- Cracks, but holds: If the glass is hit with a heavy object like a brick or a hammer, the outer pane of glass will shatter. However, the plastic interlayer holds the broken pieces together. [1, 2]
- No immediate hole: Unlike standard glass that falls away entirely in sharp shards, the shattered pieces remain stuck to the inner plastic film. [1, 2, 3]
- Requires repeated force: An intruder cannot simply smash a quick hole and reach through. They would need to repeatedly strike and manually pry/tear through the thick, tough plastic layer to get inside. [1, 2]
Security Benefits
While it is not "unbreakable," the resilience of laminated acoustic glass makes it an exceptional deterrent against forced entry, often serving as the primary security glass in high-end homes and businesses. [
1,
2]
