- Nov 19, 2021
- Cupertino, CA
- Air DE-P, Gravity DE
- Air DE Number
- 241
- Gravity DE Number
- 013
- Q1BTN5Y3
The instructions were a little unclear, so… once you have the trim piece off, the keyhole on the receiver is under the white plastic cover. Insert the key, move it to the unlocked position. Then pull the entire knob out, and only then turn it until the red stripe meets the white dot. It will lock in that position so you won’t have to hold it.
Then insert the receiver into the housing. It should take almost no force and will sound immensely satisfying to hear the click after twenty minutes of not knowing wtf to do.
The car automatically turned on tow hitch optimization, so it takes the length of the receiver into account for parking, etc.
You can then optionally switch into tow mode or turn on rear attachment optimization, depending on your needs. Once you hook up a trailer with electrical connections, it will give you the option to test the lights (which you should do), and then you must properly set the brake gain if the trailer is braked. The manual has the process for this.
Controlling the trailer brakes happens automatically, or you can pull down on the gear lever in tow mode.
TIL.
TIL.
